SRS light when really hot outside
Old Jul 29, 2006 | 05:54 PM
92ehatch's Avatar
Default SRS light when really hot outside
So i have a problem with my SRS light coming on when its really hot outside and the car sits for a while. It blinks when i turn the steering wheel.
Is there some sort of switch or something in the steering column that can cause this? if so, is it any major problem (such as my airbag might deploy on its own, or wont deploy at all if that light is on)
thanks in advance, as i dont know a thing about SRS
Old Jul 30, 2006 | 02:06 PM
hondadude's Avatar
Default Re: SRS light when really hot outside (93cb7sedan)
The is a 'spool reel' under the steering wheel, if you are sure that the motion of the steering wheel is what is turning the SRS light on. Replace it.
When the SRS light turns on the system is disabled, it won't blow up on you.
When replacing SRS parts unhook the battery negative cable and wait 3 minutes.
Old Jul 30, 2006 | 02:22 PM
accord_si's Avatar
Default Re: SRS light when really hot outside (hondadude)
thats not true i was invovled in a car accident when my srs light was on i got smashed with the air bags
Old Jul 30, 2006 | 05:57 PM
teamlegacy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">The is a 'spool reel' under the steering wheel, if you are sure that the motion of the steering wheel is what is turning the SRS light on. Replace it.
When replacing SRS parts unhook the battery negative cable and wait 3 minutes.</TD></TR></TABLE>
The proper term would be the "clock spring", but yea. That sounds like it's taking a dump.
lamboextreme
10
Sep 24, 2007 06:09 PM
steam
Sep 5, 2007 08:17 PM
erck
Jun 8, 2007 07:34 PM
delux247
Honda S2000
Feb 22, 2004 11:20 PM
