DIY shift light. check engine light. No tach.
This is a DIY for those of you that use your check engine light as a shift light. if you want to use your check engine light as a shift light then you will need somone to make a chip that has this feature. the pictures should help enough. you cannot just plug into + and - this will not work. the ground is not enough. and a direct ground will just keep the light on. this is a simple 4 way relay. this is the best way that i have found, might be an easier way. hope this helps somone.
Modified by THC07 at 8:29 PM 2/1/2007
Modified by THC07 at 6:43 AM 9/3/2008
I dont like big ugle tachs on my dash. however i like the shift light. this way its hidden cost little, any light will work. I took this light off and sold the big *** tach.
Modified by THC1107 at 12:04 AM 7/30/2006
The shift light is not activating the cel. From what I understand he just ripped the light off a tach and hooked the cel up to it so that the shift light will be in the vent and not on the cluster. I have crome and use the cel and he has crome and is looking to use something besides the cel.
BeansRSX
28
Jul 12, 2010 11:59 AM
Boosted_B_Series
Audio / Security / Video
Dec 22, 2009 10:46 PM
