need help with converting obd 1 dizzy to an obd 2 harness
i need help with wiring up a b series obd 1 dizzy (gsr) over to work with a obd 2 (97 civic) harness... i have the plugs that plug into the obd 1 dizzy i cut off a gsr harness... anyone know how to wire it up or know where i can find a wiring diagram?
Go to your local honda/acura dealer and ask someone to print you up some diagrams.
Or find someone who has Alldata or something.
the easy way is to take the obd2 internals out and reinstall them into the obd1 dizzy.
all the internals are exactly the same. only diff are the wires
i'v done this myself often.
thats the thing i dont have an obd 2 dizzy.... im running a obd 2 harness and i have an obd 1 dizzy... i need to convert the obd 1 dizzy over to work with the obd 2 harness....
Have you tried contacting Rywire.com?
Im sure they could just make you a harness to go between your obd1 distributor and obd2 harness.
cut your wires off your obd2 dizzy and color match them...it should work...
if not...try google.com for more info..they have almost everything on there...
bl
bl
SPOON_BeIgHtEeNsEe
Aug 2, 2006 10:28 AM
guyuenvy
May 16, 2002 12:27 AM
