crank pulley
Old Jul 28, 2006 | 10:26 PM
uhhhhhhhhhhhhhhhson's Avatar
Default crank pulley
will a 97 crank pulley fit a 99 h22??
Old Jul 28, 2006 | 10:30 PM
hu's Avatar
hu
Should fit with no problems.
Old Jul 28, 2006 | 10:34 PM
Default Re: (hu)
i heard there was a 5mm difference. i dont remember if it was the crank shaft or crank pulley.
Old Jul 28, 2006 | 10:36 PM
hu's Avatar
hu
I know with the H23 crank it is 95mm while the H22 is 90mm. Irrc, there is a difference with the 5th gen cranks as well.
Old Jul 28, 2006 | 10:42 PM
Rosko's Avatar
Default Re: (hu)
I think he's talking about main journal diameter of the crank... the 50mm on a 97 vs the 55 on a 99
The snout should be the same, you could also double check with hondaautomotiveparts.com as well.
Old Jul 28, 2006 | 10:43 PM
Default Re: (hu)
interesting. well imma check at honda tomorrow. thanks though
Old Jul 28, 2006 | 11:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (uhhhhhhhhhhhhhhhson)
yes it will fit. The 5mm difference you are referring to is the main journal size.
balbowskie
Jan 30, 2013 02:12 PM
atlplayer4life90
Nov 15, 2007 12:11 PM
