Turboed gsr hatch
Vehicle Description
I am selling my 92 honda civic cx h/b. It is one of the cleanest hatchs you will see for the money. Its i a dark gunmetel. Has no rust at all, and only a few dings an scratchs. The one side skirt was curbed a little bit, but not to bad. For pictures email me at icanthinkofasn16@aol.com. Car Also has a small dent in fender and a little touch up paint on it not noticable and a small dent on hood with a scratch.
Engine
gsr with gsr tranny
Mods
skunk 2 intake manifold, sparks racing turbo manifold, garret t3/t4 turbo, greddy style bov, tail wastegate an dump tube, 2.5" exhaust, Gsr rear disk brakes with drilled n slotted rotors, steel brake lines, treadstone intercooler, greddy oil adapter, auto meter boost and a/f gauges, chipped ecu running crome pro, ACT stage 2 clutch, 450cc injectors
Exterior
rota gt3's wheels ( chipped, but still look good ), carbon fiber duckbill, spoon style mirrors, Jdm fog lights, Lowered on full omni power suspension ( 1300$ new ), Interior gsr cloth font and rear seats, sony cd player with sony speakers, ex gauge cluster for tach. with clock, short shifter. Also has a drive side power window and has all wires ran through for the for the passanger side window all u need is the motor.. I ran the car for the first time on 4-19-06 and it ran a 13.9 at like 106 miles an hr. Couldn't get traction at all on bobo *** tires. Car is good for a 13.3- 13.2...
I just put in brandnew OEM head gasket, ARP head studs, water pump, timing belt. Also had a local head shop put in ferra valves. They also hot tanked the head and did a 3 angle valve job. Head also has new seels. The corner of the headgasket leaks for some reason and the oil return lines leaks a little bit too. Car will come with new oem head gasket because of its leak. It could also use new axels. I can get gator stage one axels at ur expense for 150.00$ just let me no before you pick the car up! If you have any questions please let no know. You can call me at 386-212-3252 or email me at icanthinkofasn16@aol.com. Make me an offer on the car!!
Will sell car without turbo kit wheels and duck bill for 5300.00$ U will just have to bring ur own ecu!
Modified by jaypanEG6 at 7:47 PM 8/12/2006
Engine
gsr with gsr tranny
Mods
Exterior
Oh, and at that..considering he just put in arp head studs...all this car needs is a new headgasket installed...and some slicks, and I know for a fact it'll run 12's...capable of running 15 psi easy :D
