Oil squirter not needed with forged pistons?
Just doing some homework and came across this little tidbit. Can anyone elaborate on why, or why blocking off the oil squirter would be a good thing?
the under piston oil squirter's were originally designed to keep the pistons cool. they were NOT designed to lubricate anything.....
the OEM cast pistons run hotter than aftermarket forged pistons. the forged pistons dissipate heat much better than the OEM cast pistons so many people elect to have the squirter's removed when installing forged pistons.
by removing the squirter's and plugging up the holes you gain a little more oil pressure....thats all
personally i would leave the squirter's in anyway.......in a turbo honda engine all the piston cooling you can get is a plus.....
Also with the squirters plugged you keep everything a little more equally balanced because all the oil squirters dont really put out the same amount of oil.
I know that it isnt that big of a deal. I know thats another reason some of the All-Motor guys to it in their high reving motors. Kind of to try to keep everything in the rotating mass equal
shandonwall
13
Apr 27, 2009 09:13 PM
mitchell_2kSiR
Jul 29, 2008 08:28 AM
92TypeR
13
Feb 26, 2005 11:18 AM
