Endyn/Moroso Breather kits
Old Apr 23, 2002 | 05:39 AM
Lip's Avatar
Lip
Default Endyn/Moroso Breather kits
anyone using one? and if you are...what did you do about the pcv gromit being too loose. i know what i CAN do....but looking to see if others had issues
Old Apr 23, 2002 | 05:47 AM
BlownB18's Avatar
Default Re: Endyn/Moroso Breather kits (Lip)
I got the Endyn kit on my B20Vtec, I used the ITR PCV and I also cut down the rubber gromet to lower the whole thing.I think the PCV that came in the kit was super long and The rubber piece also stuck up about 1" . I havn't had any problems with it. I also put the self drain part in that Endyn made and it works great!.
Old Apr 23, 2002 | 05:50 AM
Lip's Avatar
Lip
Default Re: Endyn/Moroso Breather kits (BlownB18)
i got a feeling that my itr block and your b20 aren't quite the same and look slightly different from your explanation. Literally the hole for the black box(actually right near the oil filter and facing same direction) where the gromit goes into is slightly too large for the gromit. the gromit is so loose fitting it will simply just fall out. thats my only issue.
thanks
Old Apr 23, 2002 | 06:02 AM
Sleeper's Avatar
Are you referring to the grommet in top of the black box(not on the B20's) where the stock pcv goes? I just used stock grommet with a stock pcv with the valve cut out of the bottom.
Old Apr 23, 2002 | 06:05 AM
Lip's Avatar
Lip
Default Re: Endyn/Moroso Breather kits (Sleeper)
No...maybe these instruction help.
PCV grommet replaces that entire black box behind your block, take off the
14mm nuts and take out the entire black box, there is a big hole in back of
the block where the black box goes to thats what you use the grommet for.
behind the block there are these huge hex bolts (gold in color) use a big
hex key to take them off, the fittings in the kit replaces the hex nuts.
Old Apr 23, 2002 | 06:20 AM
rolow's Avatar
Lip
The pcv and gromit fit in the top of the moroso can. Not the block
On my b20 I used the two threaded pieces to plug into the back of the block I had
to remove two plugs
In you instructions the hose on the pcv goes to the valve cover
The two lare hoses go to the block teh one that says drivers side should
go to the same place you removed you "black box"
Old Apr 23, 2002 | 06:30 AM
Sleeper's Avatar
I think the vtec setup is a lil different. That pcv valve and grommet is for the top of the moroso can, for closed loop. If your running with just the filter you don't need the valve. What are you using to plug the hole, where the bottom of the stock black box connects? I think with the vtec motors you keep the black box on the pass side and run a straight connector(like a pcv with the valve cut out), instead of the second nipple. Any other way and you'll need to plug the holes from the stock box, the top piece could be replace with a bolt but I don't know what you'd plug that bottom hole with. Unless you could tap it and use the plug you removed from behind the stock box, assuming the opening is the same size. I have a pic of a B20 with the nipples installed but they don't have the stock box to start with. PM me for the pic, no host.
Old Apr 23, 2002 | 06:41 AM
VTEC4GS's Avatar
Default Re: Endyn/Moroso Breather kits (rolow)
b20 blocks dont have the breather like the type R and GSR ... two different setups.
Greg
Old Apr 23, 2002 | 07:50 AM
EleanoR's Avatar
Default Re: Endyn/Moroso Breather kits (vtec4gs)
Lip i believe you have the instructions for the B20 setup that you posted. The reason i know this is because i called Rick at Endyn and after waiting a month or so they came out with installation directions for the B18C5. Pictures of where i chose to mount it can be found here: https://honda-tech.com/zerothread?id=168926
Mike
Old Apr 23, 2002 | 08:01 AM
Lip's Avatar
Lip
Default Re: Endyn/Moroso Breather kits (talkie25)
thanks. Larry just called me. i'm returning his call. I think i got it figured out
Old Apr 23, 2002 | 08:11 AM
JDM 007's Avatar
hey guys,
Can one of you please exlpain to me what this kit does? It's the first I've read anything on it.
THX
vadeR
Old Apr 23, 2002 | 08:31 AM
Lip's Avatar
Lip
Default Re: Endyn/Moroso Breather kits (vadeR)
here is a little image to help those that don't have the black box on their b20's.
and this is a breather kit http://www.theoldone.com/components/breather/
ko2performance
Mar 12, 2016 07:09 PM
Lambo123
Jul 28, 2009 09:02 PM
hondapowerb16a2
15
Oct 11, 2008 02:42 PM
descartesfool
Oct 6, 2007 11:10 AM
LSRex
Jul 19, 2003 03:01 AM
