Rough idle 89 Lxi
Old Jul 28, 2006 | 04:02 PM
jimmyv's Avatar
Default Rough idle 89 Lxi
I just bought an 89 Lxi EFI and its in good shape but it idles rough and it gets worse when I turn on electrical things like the head lights or rear defroster.It runs good when going down the road and the idle rpms is about 800. the repair invoices show that the vacuum advance was replaced and the timing belt.
Any info would be appreciated
Thanks, JIM
Old Jul 29, 2006 | 05:31 AM
Intense3.2's Avatar
Default Re: Rough idle 89 Lxi (jimmyv)
Sounds like you either need a new alternator, battery might be at the end of its days, or you need to raise your idle a lil bit.
Old Jul 29, 2006 | 01:15 PM
hondadude's Avatar
Try pinching off the PCV valve hose and if the idle smooths out replace the valve
Old Jul 29, 2006 | 03:02 PM
londonsupra's Avatar
try the cheap things first.
plugs
wires
cap/rotor
Old Jul 29, 2006 | 06:41 PM
ucd_4_life's Avatar
what do you mean idles rough? rpms go up/down or car just shakes? being how old it is try increasing the rpms to about 1000 and see if that helps it.
Old Jul 30, 2006 | 03:59 AM
Duane_in_Japan's Avatar
Default Re: Rough idle 89 Lxi (ucd_4_life)
You will only raise the idle a bit to troubleshoot, not to decrease your gas milage, does it smooth out at 1000, it may need a throttle body cleaning or a motor mount or two could be broke or very weak. Has it been getting worse gradually pointing to a tune up but why does it need a tune up now, been too long since the last one or is it burning rich, what do the plugs look like gus.
danny7560
Aug 21, 2014 01:14 AM
hondachris1994
Mar 3, 2006 06:49 AM
Phuc yiu
Jul 10, 2001 01:21 PM
