Will a Z6 tranny work with a ZC motor?
Old Jul 28, 2006 | 01:59 PM
Slo96ex's Avatar
Default Will a Z6 tranny work with a ZC motor?
As the title states, will a Z6 transmission work with either a sohc or dohc ZC motor? Searched but didn't find an answer, thanks.
Old Jul 28, 2006 | 02:02 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Will a Z6 tranny work with a ZC motor? (Slo96ex)
Yes it will - the question is what year is your car?
If you've got a 92-up Civic then yes you'll want the Z6 tranny on that ZC engine. DOHC, SOHC, VTEC, or not - it doesn't matter they fit the same.
Old Mar 14, 2011 | 01:54 PM
kano1982's Avatar
hey i just swapped my 96 lx y8 tranny on my zc with a z6 tranny everything mounted up fine but im having issues with the speedometer not reading the correct speed example it shows me going 50mph when im doing 40-45mph am i going to have to get a new guage cluster or ecu or what to get it to read the correct speed (im a noob to this still but im learning)
thanks
p.s. im having a very slight 3rd gear grind guessing its the syncro so i had the fluid swapped with syncro mesh but the guy at the shop added a quart of ATF too im thinking i should swap the fluid myself and use just gm syncromesh only
Old Mar 14, 2011 | 01:56 PM
grumblemarc's Avatar
The Grumpiest
thanks
Maybe start a new thread or search. The original question was about a swap. Yours is about a speedo.
89ED
Oct 21, 2013 03:05 AM
89CRXProject
Mar 21, 2009 02:29 AM
slocrxsi
Jul 9, 2004 11:58 AM
wannab20hatch
Sep 1, 2002 08:33 PM
B16CivicHB
33
Jan 24, 2002 07:21 AM
