how shorter does my shiftlink need to be???
i have have a 91 crx hf
and i put a b18a1 in it
i still have to put my shift link in
but i was wondering how much shorter does it have to be
i know i saw this somewhere . it gave me the inches of how much shorter it needs to be
i don't have the stock shiftlink for the crx
i only have the one from the 91 ls for the b18a1
so does any one know how much shorter it needs to be
or can someone check there shift like to tell me how long there is and then i'll see how long mine is and cut it down to the rite size
thanks for any help
from
STEVE
thanks for any help
from
STEVE
I've seen many different lengths. I installed a jdm b16a from a 90 integra and had to cut the linkage a full 3 inches. The way I determined this was to bolt the shifter up and measure how much too long it was at the transmission. This was dsdone with the car in neutral. I don't think this makres any difference but I was also converting from auto to manual in a 91 Civic DX.
i just shortened and welded mine yesterday
, and i cut out closer too, 2.5 inches, i tried it at 2 3/8 and found it was still a little long. (95ls into 91 dx with innovative mounts)...
good luck
, and i cut out closer too, 2.5 inches, i tried it at 2 3/8 and found it was still a little long. (95ls into 91 dx with innovative mounts)...good luck
I've also seen some people that cut and weld a nut and bolt on so that its adjustable...I couldnt tell you how to do it but i know there are some threads floating around here somewhere...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaD_VTAK »</TD></TR><TR><TD CLASS="quote">sorry to get off topic but ProjectDarkBlack your sig says you want a DC shell so you can ditch your pos unibody...wtf</TD></TR></TABLE>
Salvage title, due to rearended by a freight train or something similar in mass. It was then hammered back out and loaded full of bondo, ha ha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egzboy »</TD></TR><TR><TD CLASS="quote">i just shortened and welded mine yesterday
good luck
Good to know, I bought these mounts and am planning on a B18A swap soon
</TD></TR></TABLE>Good to know, I bought these mounts and am planning on a B18A swap soon
uhm i wonder how that would work
i always thot that the link would twist and **** and haveing a nut and a bolt wouldn't make it shift or something
but it would be nice to know how that is done
but i am gonna go for the 2 3/8 and see if that works
my b18a1 came out of a 90 91 ls
nice soo i am just gonna try 2 3/8 first then go from there
it's going into a crx soo that could be where some ppl are getting diff numbers from
thanks for the help
i'll be postin sum pic up as soon as i learn how 2 haha
later
thanks for the help
later
Undrgrndhaqer
Dec 21, 2003 07:50 PM
GroundZer0
Nov 17, 2002 05:15 AM
