mystery plugs?
I found some plugs by my ecu recently...
One plug has one brown, one black wire running into it..
the other plug has a white with red stripe, a black with red stripe, and a blue wire going into it..
Where are these supposed to be? They're just hanging loose now, which I presume they're not supposed to be...
I have no a/c or p/s in the car if that helps...
Thanks..
Thanks..
there are a few plugs by the ecu area. one is for the a/c thermostat, the others are check connectors to check your codes, there are also connectors for power windows, door locks... things like that...those are a bit more burried in the kick panel.
nopain20
11
Mar 5, 2016 08:47 AM
skidmarkroyalty
May 7, 2014 07:26 PM
Luserkid
20
Dec 9, 2004 10:16 PM
