Bearing problem
Old Apr 23, 2002 | 02:52 AM
ckkl's Avatar
Default Bearing problem
Hi all,
I have a "voop voop voop" sound coming from rear left wheel... I'm pretty sure it's a bad bearing, but it's not easy to find the exact part for my car since it's JDM.
Is it dangerous to drive on a noisy bearing?
Thanks
Old Apr 23, 2002 | 03:54 AM
itRgirl's Avatar
Default Re: Bearing problem (ckkl)
maybe the bearing needs to be repacked..
Old Apr 23, 2002 | 04:04 AM
Track rat's Avatar
Default Re: Bearing problem (itRgirl)
A slightly noisy bearing will usually last a good while before it fails. I wouldn't put a noisy bearing under any high speed stress, like a track event.
You can't repack them; you'll have to replace the hub/bearing unit. The part costs about $125 - 150. My guess is that US and JDM 5 lug "R" hubs are the same.
[Modified by Track rat, 1:07 PM 4/23/2002]
Old Apr 23, 2002 | 04:06 AM
Willard's Avatar
swap tires and then listen for the noise...
just a thought
Old Apr 23, 2002 | 06:55 AM
ckkl's Avatar
Default Re: Bearing problem (Willard)
My car is JDM but it's not a DC2 -- it's an EG6. Same LCA as DC2, different hub.
Actually I'm thinking of taking the car down to a track event this weekend... now I'm slightly worried... I'm getting new suspension installed in a couple days; but my workshop tells me it's not easy getting into the hub to check the bearing, and once they take it out, finding a matching spare could take a while since Honda makes so many for Civics. (i.e. take the bearing down and get them to look at it to find a match)
I'll try swapping the tyres but I'm pretty sure it's not tyre damage.
Is there anywhere I can get a quick internet education on the hub/bearing mechanism?
Thanks again
Old Apr 23, 2002 | 07:49 AM
SpecR_EK's Avatar
New User
Do you have any other models of integras out there? The bearing out of a non-type R model should fit the EG6.
scruffyduck
Honda S2000
Feb 21, 2012 04:38 PM
tcsubaru
Jan 11, 2012 09:49 AM
zrickety
18
May 9, 2008 09:00 PM
vjace
Feb 9, 2005 03:44 PM
MajBach
Jul 12, 2003 10:39 PM
