b20vtec
Old Jul 28, 2006 | 12:54 AM
del_slow420's Avatar
Default b20vtec
i am curently building a b20bvtec i have new crank and rod bearings, 11.9:1 comp pistons,golden eagle crvtec kit, arp head studs, b16a3 head, duel valve springs, gsr cams, full exhaust, cold air intake, fpr, stock b16 p30 ecu i was woundering if someone could tell me what the safest rpm is that the bottem end will hold up to and i can rev to with this build
Old Jul 28, 2006 | 12:57 AM
JDMlyfestyle's Avatar
Hmm u have High compression pistons on stock rods? i wonder how thats gonna work considering aftermarket rods and pistons require spiral locks and OEM Rods Are Pressed pins.
Old Jul 28, 2006 | 02:47 AM
fmrprojects's Avatar
Default Re: (JDMlyfestyle)
get some bigger cams to get the most outta the compression. chip the ecu for crome and get it tune. get some rod bolts or aftermarket roda and you can rev up safely to 8500rpm
bradabu
27
Mar 26, 2012 08:40 AM
93egboosted
20
Jun 10, 2008 05:10 AM
Snizzoop
Jul 23, 2006 06:56 AM
b20vtechatch
Jun 1, 2006 07:50 AM
Fuzion
10
Feb 11, 2004 08:21 AM
