JDM ITR recaro's into EF CRX ??
Old Jul 27, 2006 | 11:34 PM
DALLEN's Avatar
Default JDM ITR recaro's into EF CRX ??
ok so i bought a pair of black itr recaros and am having trouble making brackets for them if anyone knows of aftermarket brackets or an easy way to build my own brackets please post up any info you have thanks
P.S. iv searched for about 3 weeks without any results so please dont suggest the search option!!!! thanks
-Dallen
Old Jul 28, 2006 | 12:51 AM
roterx7's Avatar
swap the seat pans so you can use your stock brackets
Old Jul 28, 2006 | 02:46 AM
salman's Avatar
you have to make some alteration with the Hooks,
Old Jul 28, 2006 | 03:03 AM
Moto-hashiriya's Avatar
Default Re: (salman)
Just buy some aftermarket "low position" Recaro seat rails for an EF and call it a day
Old Jul 28, 2006 | 12:01 PM
DALLEN's Avatar
aftermarket seat rails can you suggest a brand or site i cant seem to find conversion rails? anyway just to clear things up i have the JDM itr recaros not USDM so the seatpan switch wouldnt work but thanks for the suggestion
Modified by DALLEN at 1:26 PM 7/28/2006
Old Jul 28, 2006 | 12:24 PM
YumVTEC's Avatar
Default Re: (roterx7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roterx7 &raquo;</TD></TR><TR><TD CLASS="quote">swap the seat pans so you can use your stock brackets</TD></TR></TABLE>
are you f'ing kidding? maybe if they were USDM ITR seats that could possibly work, but he's asking about JDM ITR recaro seats, which are a completely different animal. you definitely can *NOT* switch the pans to use EF rails.
to the OP, get recaro rails made for your car and bolt them to the seats.
Old Jul 28, 2006 | 12:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (YumVTEC)
DALLEN, would you mind measuring the space between all the bolt holes on the bottom of the recaro seats (I assume there is 4 holes). Perhaps someone could come up with something for you. I would sure like to know the distance between the two front holes, the two rear holes, and the distance between the front & rear holes on both sides. Also the diagonal measurements...
I guess like this:
o-o
o-o
Old Jul 28, 2006 | 12:51 PM
DALLEN's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">DALLEN, would you mind measuring the space between all the bolt holes on the bottom of the recaro seats (I assume there is 4 holes). Perhaps someone could come up with something for you. I would sure like to know the distance between the two front holes, the two rear holes, and the distance between the front & rear holes on both sides. Also the diagonal measurements...
I guess like this:
o-o
o-o</TD></TR></TABLE>
ok the measurments are (from the center of each bolt hole)
measure's 16 inches accross the two front holes and there are a set of holes one inch behind these holes that also measure 16 inches accross there are two holes at the back that measure 16 inches across and from the back hole to the front ones are 9 and 1/4 inches to the closes set and 10 1/4 inches to the closest set to the front thanks
o o
o-o
|\/|&lt;--------------------- as you you can see there are two sets of holes at the front
|/\| if you couldnt visualize that during the write up.....lets see
o-o what you guys can come up wiht thanks !!!!!!
Old Jul 28, 2006 | 12:52 PM
Default Re: (94eg!)
Over here in Japan there are a lot of "generic" Recaro/Bride low position seat rails that most parts shops sell. I am assuming that any shop that sells Recaros or Brides should sell them. Before someone says anything the bolt pitch is different between Recaros and Brides but they have seat rails that can be used for both
Old Jul 28, 2006 | 01:39 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (TR808)
Now I just need to measure the bolt holes in the stock seat rails for a CRX. I've seen a thread about making 1/4" aluminum plate adapters to bolt aftermarket seats to OEM sliders (click here for details). I would really like to know if this would work for a CRX. The guy says the plates always pass tech inspection too...
Thanks for taking the measurments man...
Do you know if using all 6 bolt holes is required, or are the extra front ones there to allow more install options?
Old Jul 28, 2006 | 02:31 PM
DALLEN's Avatar
i have no idea i would asume that you would have to use all 6 but who knows.......let me know what you can come up wiht thanks alot man i really appriciate it!!!
Old Jul 29, 2006 | 02:57 PM
FakeJDMEF8's Avatar
im interested too..
anyone do this?
how do they sit? higher or lower than normal?
Old Jul 29, 2006 | 07:37 PM
DALLEN's Avatar
Default Re: JDM ITR recaro's into EF CRX ?? (DALLEN)
im not to sure they are about the same hight as stock maybe a little shorter so it all depends on the brackets you make or buy i guess!!!
Old Jul 29, 2006 | 07:45 PM
EF_LSVtec's Avatar
Put 2 flat bars (bought at local hardware) across each seat. Mount stock railings on the flat bars. Use Washers to level the seat... Cost for both seats, less than $50...
Old Jul 29, 2006 | 07:51 PM
Sifu's Avatar
Kind of a n00b question but I saw some yellow jdm itr's today. They were quite dirty and beat up and there was like a "gap" between the back support and the lower piece. Is the gap normal on these recaro's?
Old Jul 29, 2006 | 07:52 PM
Tippyman's Avatar
Interesting, I don't know how it's hold up in an accident though!
Old Jul 29, 2006 | 08:04 PM
EF_LSVtec's Avatar
Default Re: (Tippyman)
It depends what kind of bolts you're using but basically, no matter if you're using stock sliders or aftermarket ones. Bottomline, you get into an accident you better be wearing a seat belt.
Old Jul 29, 2006 | 08:08 PM
DALLEN's Avatar
Default Re: JDM ITR recaro's into EF CRX ?? (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">
Put 2 flat bars (bought at local hardware) across each seat. Mount stock railings on the flat bars. Use Washers to level the seat... Cost for both seats, less than $50...</TD></TR></TABLE>
those look really good thanks I think im going to try this !! do you have any pics of the car from the front!!!
Old Jul 29, 2006 | 08:59 PM
EF_LSVtec's Avatar
Old Jul 29, 2006 | 09:36 PM
Tippyman's Avatar
Damn boy, that's a nice shot! 3-wheelin action!
Old Jul 29, 2006 | 10:30 PM
La EF-8's Avatar
Damn those seats look awesome I wish i had the cash for the real thing, but until then Recaro speeds will have to do.
Old Jul 30, 2006 | 04:07 PM
DALLEN's Avatar
those look awesome i'll post pics when i put 'em in my ef this week!!!!!!
Old Jul 30, 2006 | 04:16 PM
JapJunkie's Avatar
Default Re: (DALLEN)
Dont forget to post fo sho.
neozero999
Nov 6, 2008 02:47 PM
pnoi_01dc2r
Aug 5, 2006 01:19 PM
whiteef-8
18
Oct 13, 2005 01:39 PM
Mr.Fairlady
Jul 10, 2004 11:06 AM
