Has anyone weighed the rear drums VS rear discs?...
Old Jul 27, 2006 | 09:09 PM
*Boostwerks*'s Avatar
Default Has anyone weighed the rear drums VS rear discs?...
I was told by a couple people that the rear drum brakes/trailing arms are lighter than the rear discs/trailing arms. I'm just wondering if anyone has actually weighed both assembilies?
I am about to completely rebuild my rear suspension, and am contemplating if I should just stick with rear drums.
BTW, rear build list...
Mugen trailing arm bushings
D2 LCAs
ST sway bar
custom heim toe links
custom heim camber links
custom upper/lower strut bars
Modified by Bryson at 12:27 AM 7/28/2006
Old Jul 27, 2006 | 09:13 PM
project ak's Avatar
Default Re: Has anyone weighed the rear drums VS rear discs?... (Bryson)
well just get disk brakes cost mort but saves your car from minor accidents.
Old Jul 27, 2006 | 09:16 PM
Default Re: Has anyone weighed the rear drums VS rear discs?... (project ak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project ak &raquo;</TD></TR><TR><TD CLASS="quote">well just get disk brakes cost mort but saves your car from minor accidents.</TD></TR></TABLE>
Not the kind of response I was looking for. Nor does it make any logical sense.
Old Jul 27, 2006 | 09:59 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i believe there were posts in the auto-x forum with the weight figures.
it is a general consensus that the disc set-up does weight more than a drum set-up. an alunimium drum set-up from the first gen CRX weighs even less.
i have no numerical data to factualize this.
Old Jul 27, 2006 | 10:26 PM
Default Re: Has anyone weighed the rear drums VS rear discs?... (Ash J. Williams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ash J. Williams &raquo;</TD></TR><TR><TD CLASS="quote">i believe there were posts in the auto-x forum with the weight figures.
i have no numerical data to factualize this.</TD></TR></TABLE>
Thanks! Yeah, I'm just trying to get a feel for exactly how much lighter they are. If it's only a couple pounds, then I'll definetly get the discs.
Old Jul 27, 2006 | 10:36 PM
sanimalp's Avatar
$cat /dev/urandom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes &raquo;</TD></TR><TR><TD CLASS="quote">
A drum brake set-up weighs 32.5 pounds.
A disk brake set-up weighs 39.5 pounds.
That was measured using a cheap bathroom scale, so the numbers may not be accurate, but the 7 pound difference should be fairly "real". It was done on the same day, using the same scale.
This was for the trailing arm, all brake hardware with hubs, spindles and all. No "link" arms attached.
Wes
from this forum post https://honda-tech.com/zerothread?id=250891
Old Jul 27, 2006 | 10:41 PM
Awsome, thanks a lot!
Looks like I'll be keeping the drums.
Old Jul 28, 2006 | 10:43 AM
Jaker's Avatar
Default Re: (Bryson)
And the 86-87 CRX HF aluminum drums are 3 pounds lighter per side than the 88-91 Civic/CRX iron drums. The aluminum ones are 4 pounds each, the iron ones are 7 pounds each.
Old Jul 28, 2006 | 10:48 AM
CRX Toad's Avatar
What are you saying? No one understand engrish.
I can say that out on track when I am coming into a turn under heavy braking I cannot tell the difference between drum or disc in the rear. IMO the only thing the disc do is clean up the look in the back and make it easier to change pads vs shoes which neither are a good reason to change to disc brakes.
The answer quoted from the link above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">A drum brake set-up weighs 32.5 pounds.
Wes</TD></TR></TABLE>
Old May 10, 2010 | 10:05 AM
Jenkinsal2's Avatar
Being that there are some really knowlageable posters in this thread Im bringing it back. I have found little to no information about swaping from my 91 DX Drums to HF for obvious reasons. What I am wondering is what parts are necessary to swap to the lighter HF rear Drums? Do i need any new trailing arms, Hubs, ect. The suspension is all off the car for now so its the best time to do this.
This is for autox use if anybody was wondering. Thanks!
Old May 10, 2010 | 11:43 AM
Tyson's Avatar
take drum off, put 1g HF aluminum drum on.
adjust brakes as needed.
Old May 10, 2010 | 12:16 PM
jonessw20's Avatar
Just curious to know if anyone has checked the rotational mass differences? I know the disc set up is heavier but what about just the disc compared to just the drum?
Old May 10, 2010 | 12:21 PM
Tyson's Avatar
honestly, i think if you are THAT concerned about the minute differences in moments of inertia... you ought to be more concerned about your driving.
meaning, dont bother dissecting the weight differences. its not a big deal.
Old May 10, 2010 | 12:53 PM
jonessw20's Avatar
yes it is true that it isnt a big difference but then i guess the answer to the whole point of this thread might as well of been answered dont worry about it its not a big difference as well. Just wondering thats all. i was considering doing the rear disc set up eventually but i am really knocking that further down the list of things to do now since everyone seems to say the drums are nearly as good as the discs and also lighter.
Old May 10, 2010 | 02:57 PM
Tyson's Avatar
indeed, its not a big difference drum vs disc.
stick to your drums. the rears do very little braking.
Old May 10, 2010 | 04:04 PM
Jenkinsal2's Avatar
Thanks Tyson! Am I correct that the 85-87 HF was the one with the AL Drums?
Old May 10, 2010 | 04:19 PM
Tyson's Avatar
1g crx hf = 84-87 crx hf. yes...
slowteg97
Suspension & Brakes
10
Feb 7, 2008 12:45 AM
Tweakmeister
26
Jan 4, 2005 01:17 PM
grandmasterflex
Jun 17, 2004 10:53 AM
soundbomber
20
Jan 20, 2004 02:29 PM
