Using bronze valve guides in an h22a
Old Apr 23, 2002 | 12:22 AM
aeolus's Avatar
Default Using bronze valve guides in an h22a
I asked this question earlier,but i wanted to see more responces from people who have used bronze valve guides on there daily driven head.Any problemswith them?Do they wear out alot faster than the stock cast iron ones???Thanks!
Old Apr 23, 2002 | 04:50 AM
Mikey3000's Avatar
Default Re: Using bronze valve guides in an h22a (aeolus)
i bought some ferrea and never had them installed because it was gonna cost a lot. i don't think they wear out faster than the stock ones because they are more resistant to heat.
Old Apr 23, 2002 | 06:24 AM
H22Si's Avatar
Default Re: Using bronze valve guides in an h22a (Boss Hogg)
They should wear at a slightly lesser rate. Bronze is more "slippery" when it comes to friction.
Old Apr 23, 2002 | 06:37 AM
Spade's Avatar
Default Re: Using bronze valve guides in an h22a (H22Si)
:thumpup: Less friction that is why people get them......
Old Apr 23, 2002 | 06:53 AM
2point6's Avatar
Default Re: Using bronze valve guides in an h22a (Spade)
I use them in my set up and they work great. They also dissipate heat faster (so it is said) SI industries makes the ones I use.
Old Apr 23, 2002 | 04:23 PM
aeolus's Avatar
Default Re: Using bronze valve guides in an h22a (2point6)
Those are the ones are ordered too from SI....Are u using there valves also???
fast92hatch
May 15, 2007 02:28 PM
Black DC2
Jul 21, 2003 07:02 PM
baonest
Aug 25, 2002 08:16 PM
