ls-vtec cutting out
Old Jul 27, 2006 | 07:35 PM
GsrTurboCRX88's Avatar
Default ls-vtec cutting out
My car has started cutting out whenever I am in low rpms. I loosend the distrtibutor and moved it up a little bit and then it would run fine. Then after driving it for a while it would do it again. Is my timing off or could it be something else?
Old Jul 27, 2006 | 08:02 PM
latinracerct's Avatar
Default Re: ls-vtec cutting out (GsrTurboCRX88)
could be a bad sensor or try raising your idle up a little it could also be you timing off a tad use a timing gun to check that
Old Jul 27, 2006 | 08:11 PM
Default Re: ls-vtec cutting out (latinracerct)
I adjusted the idle but it dont seam to help
Old Jul 27, 2006 | 10:19 PM
it could also be your throttle body maybe it closes all the way try cleaning it or replacing it completely its happened to me before
Old Jul 28, 2006 | 07:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by latinracerct &raquo;</TD></TR><TR><TD CLASS="quote">it could also be your throttle body maybe it closes all the way try cleaning it or replacing it completely its happened to me before</TD></TR></TABLE>
I will try that. The spring was stuck clesed where the throttle cable goes in before i put the motor in. I had to put alot of forse to open it and I wd40'd it and it was a little better
Old Jul 29, 2006 | 08:35 PM
cool good luck with that and let me know
Old Jul 31, 2006 | 03:48 PM
I think it might be my Throttle position sensor. I noticed that it is broken
Old Aug 1, 2006 | 08:27 PM
i dont think itll cause it to cut out but hey worth a try and again good luck wit that
good apollo
Jan 16, 2008 08:48 PM
k_lude
Sep 2, 2006 09:20 PM
cbcrx87
Aug 13, 2006 10:32 AM
AC2i0v0i0c
Oct 21, 2004 08:08 AM
Rob Dizzle
Apr 18, 2003 08:50 PM
