someone help!!! no turn signals
Ok so i have a 96 civic hatch dx. And i traded my friend gauge clusters his had a tech and my cluster did not. so i put it in and now my turn signals dont work. i checked the fuse and its fine. so i dont know what to do know. can someone please help me out.
Modified by Ekhatch84 at 7:00 AM 8/1/2006
You did not disconnect the hazzard button for any reason did you? I know in the fifth gens if the hazzard button is not hooked up the signals will nto work, it might be the same for the sixth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmitbyh »</TD></TR><TR><TD CLASS="quote">You did not disconnect the hazzard button for any reason did you? I know in the fifth gens if the hazzard button is not hooked up the signals will nto work, it might be the same for the sixth.</TD></TR></TABLE>
its the same in the 6th gens as well.
have your friend take out his cluster again and put it back into your car and see if the signals work then.
no i did not disconnect the hazzard. but i will check again with my old cluster. i would it be if it does work ok in my old cluster and not in my new one? is it the cluste?
HogHead
28
Apr 10, 2014 03:30 PM
mr.4door
Nov 5, 2006 05:03 PM
