Easy answer: 92 Accord Ex Trouble code. Tell me what the codes mean. PLEASE NO LISTS OF CODES
Old Jul 27, 2006 | 01:31 PM
seancoleshill's Avatar
Default Easy answer: 92 Accord Ex Trouble code. Tell me what the codes mean. PLEASE NO LISTS OF CODES
Ok. I have a simple problem (i think)
I own a 92 accord ex 5spd.
I put a jumper into the blue socket where the ECU was. I turned the car on and the MIL/check engine light came on in this way:
On
Off (Long pause)
On
Off (short pause)
On
Off (long pause)
(starts over again)
My car has no power under 2500 rpm, I can floor it and its the same as me lightly accelerating no matter what gear im in. It also leaks a little oil and recently it does not start up on occation.
Being 18 Im not loaded so I wanna save money by attempting fixes on my own if i can.
Thanks for your help
Modified by seancoleshill at 3:43 PM 7/27/2006
Old Jul 27, 2006 | 02:13 PM
Intense3.2's Avatar
Default Re: Easy answer: 92 Accord Ex Trouble code. Tell me what the codes mean. PLEASE NO LISTS OF CODES (s
Thats code 11.
Old Jul 27, 2006 | 02:17 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 &raquo;</TD></TR><TR><TD CLASS="quote">Thats code 11.</TD></TR></TABLE>
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen
riiiiiiiiiiiiiiiight
Old Jul 27, 2006 | 02:42 PM
Thank you for your help, turns out its a code 12.
Ive search over the net and it seems I have a problem with my solenoid which interestingly enough has something to do with the EGR.
Any ideas?
Modified by seancoleshill at 4:00 PM 7/27/2006
Old Jul 27, 2006 | 02:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seancoleshill &raquo;</TD></TR><TR><TD CLASS="quote">Thank you for your help, turns out its a code 12.
Any ideas?
Yes, the solenoid opens the EGR. What is it doing?
Old Jul 27, 2006 | 03:01 PM
Well, the egr has to do the exhaust. My car sounds like it has no muffler, like it has a hole in the exhaust.
Old Jul 27, 2006 | 03:03 PM
Old Jul 27, 2006 | 03:50 PM
hondadude's Avatar
replace the EGR valve, the lift sensor is bad.
Old Jul 27, 2006 | 05:52 PM
Thats basically the perfect answer. My car also doesnt start in hot weather. If I let it cool down it starts. It runs totally fine besides the no power before 2500. By the way, any past or present help is much appreciated.
ilovevtec951
Jun 22, 2015 07:38 PM
Prelude_lunatik
Jun 30, 2006 06:34 PM
MugenAccorn
Jan 25, 2006 05:43 PM
hatchinprogress
Sep 12, 2005 05:34 AM
