rear fog/brake light installation problems?
Old Jul 27, 2006 | 01:31 PM
jugodmyko's Avatar
Default rear fog/brake light installation problems?
i just got my rear brake/foglight from jdmland.com. how do i install it and wire it up?
Old Jul 27, 2006 | 01:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: rear fog/brake light installation problems? (jugodmyko)
The rear fog lamp should be wired to an ignition-switched 12V source, with its own separate on/off switch.
Old Jul 27, 2006 | 02:03 PM
jugodmyko's Avatar
the guy told me it was optional that i could get the switch or i can just connect it to my brake lights so when i brake it lights up as well?
Old Jul 27, 2006 | 02:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: (jugodmyko)
Well, if you want it to function as some sort of extra brake light, then you can just splice the wiring into your existing brake lights. However, that is not how a rear fog lamp is intended to function.
Old Jul 27, 2006 | 02:44 PM
Sleepy_Red_hatch's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Well, if you want it to function as some sort of extra brake light, then you can just splice the wiring into your existing brake lights. However, that is not how a rear fog lamp is intended to function. </TD></TR></TABLE>
yup, he's got it. or you can run a wire from your foglight switch to the back and have it turn on with your foglights
JDMlyfestyle's Avatar
if you really want the foglight to be functional then you should wire it up with your foglight switch.
Old Jul 27, 2006 | 03:40 PM
Padawan's Avatar
Darth ModerVader
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">if you really want the foglight to be functional then you should wire it up with your foglight switch.</TD></TR></TABLE>
Drawing power from the fog lamps is fine (in many cars, the front fog lamps must be on in order for the rear lamp to function), but if you want it wired correctly, it should still have a separate switch.
Old Jul 27, 2006 | 03:50 PM
well since the Rear fog is meant for poor weather conditions and foglights help in poor weather conditions why not just have them on in the same switch?
Old Jul 27, 2006 | 04:02 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">well since the Rear fog is meant for poor weather conditions and foglights help in poor weather conditions why not just have them on in the same switch?</TD></TR></TABLE>
Well, in countries that require a rear fog lamp, there are also rules in place regarding its usage. One of the rules limits the speed at which you can be traveling with the lamp on. There are different situations where it might be appropriate to use the front fog lamps but not the rear, and thus they require the rear fog lamp to have its own switch as well as an illuminated indicator that the driver can see.
frustrated1965
Aug 18, 2024 10:00 AM
derrickjon
Aug 4, 2009 06:09 PM
kevinm1981
Jul 28, 2009 06:34 PM
trooper0641
Nov 21, 2008 04:03 AM
eavtimmy
Audio / Security / Video
Jun 11, 2005 06:29 PM
