can you use oem pan gasket with moroso pan?
I bought a moroso oil pan, the one that looks identical to the stock one. Wondering if you can use the stock gasket and what to torque the bolts to? This is the second time i've replaced it and it leaks around the entire gasket. I tightened the bolts to 50 inch lbs.
I just got them all snug to where the rubber just started to bulge. Then I went around the pan a few more times to make sure they were all snug. I put a thin bead of grey Permatex on the motor and the pan to hold it in place. If you get it too tight the rubber will split between the holes and the gasket is useless after that.
