surging then it wont start please help
Old Jul 27, 2006 | 01:05 PM
davidcrx89's Avatar
Default surging then it wont start please help
i have a civic ef station wagon with real time 4wd and it has the multi point 1.6L in it well it will run fine then all the sudden it will just start surging up to 3000 rpms then when you turn it off it wont start again for about 10 to 15 minutes and i took out the relay and fixed it and it still does it any one know what the problem is thanks in advance for the help
Old Jul 28, 2006 | 11:18 AM
davidcrx89's Avatar
Default Re: surging then it wont start please help (davidcrx89)
please help
Old Jul 28, 2006 | 11:40 AM
ghost_ryder35's Avatar
vaccum leak? use soapy water to check that.
Old Jul 28, 2006 | 12:42 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: surging then it wont start please help (ghost_ryder35)
Soapy water won't blow bubbles with a "vacuum" leak...
Old Jul 28, 2006 | 02:01 PM
gp70hs's Avatar
I would try checking or replacing the fuel filter or checking the pressure on the fuel rail. It might also be the fuel pump is starting to go on the fritz.
DA9b0y303
29
Aug 21, 2013 03:51 PM
88EFsedan2
14
Feb 11, 2012 09:17 PM
IIDIEIV619
18
Oct 11, 2006 11:54 AM
LScivic_wpg
13
Feb 9, 2006 01:49 PM
gumbybum
Oct 9, 2002 11:22 AM
