GSR ABS Axle work with non-abs?
Old Jul 27, 2006 | 01:00 PM
SavEM1's Avatar
Default GSR ABS Axle work with non-abs?
I put a abs axle in my EM1 and now I hear clunking everytime I let off the throttle and then give it throttle again. Is it because this is an ABS axle or what else could it be?
Old Jul 27, 2006 | 01:01 PM
tatmark1's Avatar
bad axle maybe?
Old Jul 27, 2006 | 01:48 PM
Slopoke's Avatar
Default Re: GSR ABS Axle work with non-abs? (Hcivic02)
I have abs axles in my non abs car, right now. No problems at all.
I would double check to make sure all the suspension parts you touched while replacing the axle are tight.
Old Jul 27, 2006 | 01:51 PM
del_slow420's Avatar
Default Re: GSR ABS Axle work with non-abs? (Slopoke)
i run non abs axles in my b16 del sol with abs but the abs is already messed up its just got the ring for the sensor...
Old Jul 27, 2006 | 02:00 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: GSR ABS Axle work with non-abs? (del_slow420)
Running ABS axles in a non-ABS car is 100% fine and a lot of axle remanufacturers don't even offer non-ABS any more because it's a PITA for them to stock both types.
You have another problem not associated with the ABS ring probably, but at least make sure it's not scraping against anything and make sure it's on evenly and not cocked to the side or anything.
EG civic
Nov 11, 2020 11:44 PM
czissman
Transmission & Drivetrain
Oct 22, 2009 05:33 PM
felixjr18
Dec 21, 2008 07:22 PM
94_teggy_rs
Jan 28, 2008 08:36 PM
BB4
Mar 9, 2006 07:46 PM
