new item "GREDDY Intelligent Informeter"
Old Jul 27, 2006 | 12:28 PM
JJ-Built's Avatar
Default new item "GREDDY Intelligent Informeter"
...first off.. I've searched around on H-T and nothing came up...
Does anybody on here have and uses this new item from GREDDY?
Is it worth it? Does it work well with chipped ecus?
<U>This is what it says:</U>
The Greddy Intelligent Informeter is a great looking, but inexpensive alternative for monitoring your vehicle’s parameters using the factory OBDII Port.
Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and data log your vehicles performance though it's own OBD sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Data log up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offers endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
More info here: http://www.trust-power.com/ove....html
thanks-
Old Jul 27, 2006 | 12:32 PM
guibo's Avatar
Default Re: new item "GREDDY Intelligent Informeter" (JJ-Built)
bump bump i wanna know too! it sounds mighty interesting..
Old Jul 27, 2006 | 12:33 PM
kay_animation's Avatar
Default Re: new item "GREDDY Intelligent Informeter" (guibo)
Someone help this guy get rid of his fields
JJ-Built's Avatar
yess interesting.. on top of that.. it looks cool..
Old Jul 27, 2006 | 01:25 PM
ecahatch's Avatar
Senor Miembro
from what i read...it seems very handy.
we need real reviews tho
Old Jul 27, 2006 | 01:49 PM
.:Made in OC:.'s Avatar
i like it... kinda looks like a mp3 player.
Old Jul 27, 2006 | 05:31 PM
JJ-Built's Avatar
Default Re: new item "GREDDY Intelligent Informeter" (Made In OC)
yea.. it sure does..
Old Jul 27, 2006 | 09:07 PM
willywong's Avatar
wow you can change the face plate thingy too... soo many colors.... but it only works off the ecu..so... oil press, fuel press, etc.; out of the question??
Old Jul 28, 2006 | 06:34 AM
JJ-Built's Avatar
Default Re: (willywong86)
more info...
Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp.
For use with veichles wich use OBD2 Ports, a cigarette lighter plug powers up the unit.
Features a easy to read Color LCD Screen, Monitor Record and Playback, and 180 Degree Monitor Flexibility.
Old Jul 28, 2006 | 07:05 AM
ecahatch's Avatar
Senor Miembro
bump for more info! and personal reviews
Old Jul 28, 2006 | 09:01 AM
-Gambit-'s Avatar
Default Re: (ECAhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">bump for more info! and personal reviews </TD></TR></TABLE>
Old Jul 28, 2006 | 11:37 AM
JJ-Built's Avatar
Default Re: (moops vs moors)
it works on all OBD2 cars.. meaning a or b
and its not for tuning.. its for monitoring..
Old Jul 28, 2006 | 12:18 PM
-Gambit-'s Avatar
Default Re: (JJ-Built)
Will it work say if you still have the obd2 harness but your engine is obd1 such as my car.
Old Jul 28, 2006 | 12:27 PM
.dave's Avatar
i HAS questions ?
Default Re: (-Gambit-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- &raquo;</TD></TR><TR><TD CLASS="quote">Will it work say if you still have the obd2 harness but your engine is obd1 such as my car.</TD></TR></TABLE>
I'm going to guess that you'd need and OBD2 connection port under the dash and need to be running an OBD2 ECU. Also, this probably won't work on OBD2 cars running Hondata, Crome, etc on a chipped OBD1 ECU.
Old Jul 28, 2006 | 12:30 PM
-Gambit-'s Avatar
Default Re: (daveG)
i still have the obd2 port under the dash, im just running a obd1 ecu and a obd1 motor. But its still the obd2 harness. So in my case it wont work, we are assuming.
Old Jul 28, 2006 | 12:37 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- &raquo;</TD></TR><TR><TD CLASS="quote">i still have the obd2 port under the dash, im just running a obd1 ecu and a obd1 motor. But its still the obd2 harness. So in my case it wont work, we are assuming. </TD></TR></TABLE>
I'm willing to be money that it won't. OBD1 ECUs can't talk to normal OBD2 code readers even if the OBD2 port is there.
In my opinion all these OBD2 scan gauge things are kind of pointless anyways and just for bling.
Old Jul 28, 2006 | 12:46 PM
TheHooded_Mike's Avatar
Default Re: (daveG)
List price is $360 on the greddy site.
Old Jul 28, 2006 | 01:37 PM
JJ-Built's Avatar
Default Re: (TheHooded_Mike)
thats what I want to know.. I'm currently using an OBD1 P72 ecu.. and on top of that.. I'll soon be using a chipped p28..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">
I'm willing to bet money that it won't. OBD1 ECUs can't talk to normal OBD2 code readers even if the OBD2 port is there. </TD></TR></TABLE>
exactly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheHooded_Mike &raquo;</TD></TR><TR><TD CLASS="quote">List price is $360 on the greddy site. </TD></TR></TABLE>
I've seen it go for $249.. go froogle it if ur interested in buying one.. make a review for us
Old Jul 28, 2006 | 02:38 PM
I'd be tempted to get one somewhere down the line, but I have other things to take care of first. I need a few more parts here and there before I can get my turbo setup going. Also have CC bills to worry about lol...
Old Jul 29, 2006 | 06:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">no code reader built in? Booo</TD></TR></TABLE>
Those stand-alone code readers are like a grand so I wouldn't expect it to have that feature.
Old Jul 30, 2006 | 08:06 AM
.RTErnie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJ-Built &raquo;</TD></TR><TR><TD CLASS="quote">thats what I want to know.. I'm currently using an OBD1 P72 ecu.. and on top of that.. I'll soon be using a chipped p28..
exactly...
I've seen it go for $249.. go froogle it if ur interested in buying one.. make a review for us </TD></TR></TABLE>
I'll see what I can get them for and hook someone up if they'll do a review IM me if you're interested and I'll get you a price come monday.
-Eric
Old Aug 27, 2007 | 07:59 PM
dannydos's Avatar
Default Re: (.RTErnie)
bump.....who has one
sndc5
Mar 15, 2007 06:18 PM
sndc5
Feb 5, 2007 01:54 PM
