P72
Old Jul 27, 2006 | 12:09 PM
ATrin's Avatar
Default P72
I have a 97 GSR in my 94dx coupe. My friend told me that a P72 ecu is the wrong ecu for my 97gsr motor. Is he right??
Old Jul 27, 2006 | 12:12 PM
ek4_b16a's Avatar
Default Re: P72 (ATrin)
ummmm.....sorry but your buddy is wrong on that...just as long as you get an obd1 p72 (gsr ecu), you will be fine! tell your friend that he doesn't know jack...just make sure you get a gsr ecu (p72) out of a 94-95...cause 96-00 is obd2...that won't work...good luck with the car and your friend there...
Old Jul 27, 2006 | 12:14 PM
ATrin's Avatar
Default Re: P72 (ek4_b16a)
kewl thats what i though. now i just have to find out if my cousins p72 is obd1.
Old Jul 27, 2006 | 12:16 PM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATrin &raquo;</TD></TR><TR><TD CLASS="quote">kewl thats what i though. now i just have to find out if my cousins p72 is obd1.</TD></TR></TABLE>
Well just try plugging it into your harness. The plugs are different for OBD1 and OBD2 so if it doesn't fit then its not OBD1
Old Jul 27, 2006 | 01:14 PM
ATrin's Avatar
Default Re: P72 (SkoundrelUSA)
yea i'm gonna swing by and pick it up. so there's no issues running an obd1 P72 on a 97gsr? just want to make sure. thx
Old Jul 27, 2006 | 01:46 PM
H9Omega's Avatar
nope thats the best ecu to use, unless you buya p28 and get it chipped.
Old Jul 27, 2006 | 02:02 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (H9Omega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H9Omega &raquo;</TD></TR><TR><TD CLASS="quote">nope thats the best ecu to use, unless you buya p28 and get it chipped.</TD></TR></TABLE>
The only time a rechipped P28 can even benfit a GS-R engine is if the GS-R engine doesn't have the stock dual butterfly intake manifold. If you have the stock GS-R intake manifold then KEEP that P72 ECU and make sure the knock sensor and secondary/IAB wires are hooked up for optimal performance until you begin tinkering with different cams, intake manifold, etc.
Old Jul 27, 2006 | 03:35 PM
ATrin's Avatar
Default Re: (B18C5-EH2)
I know what the iab/butterfly does but what does iab stand for? I don't plan on getting an aftermarket manifold so, yea i'll just pick up the p72. i need to get the iab's and knock sensor wired though.
Old Jul 28, 2006 | 05:27 AM
ATrin's Avatar
Default Re: (ATrin)
Nope its odb2. damn!
Old Jul 28, 2006 | 08:55 AM
miahmouse's Avatar
Default Re: (ATrin)
Intake Air Bypass
something to remember with the wiring of the secondaries. OBD1 p72 sends ground to the IAB solenoid. The other wire gets hooked up to a switched positive (easiest place to hook to is at the fuse panel).
edit: and the KS has to be wired up, it'll fall on it's *** without....
Old Jul 28, 2006 | 08:59 AM
fmrprojects's Avatar
Default Re: (miahmouse)
if your model is a dx you are gonna have to wire up knock, vtec, iab to get the p72 to work correctly
Old Jul 28, 2006 | 09:29 AM
ATrin's Avatar
Default Re: (fmrprojects)
If for some reason i can't get a hold of a P72, what will i need to do to my P28 to make it run correctly??
Old Jul 28, 2006 | 09:45 AM
Syndacate's Avatar
wait, uhhh I'm confused...why are pple telling him to get an ODB1?????
If u have a 97 GSR motor, u want an ODBII P72, I do believe...., wasn't ODBII enstatd 96+? Unless u have a conversion harness ((ODBII &gt; ODBI)then everything would be peachy) the plugs won't even fit into the ECU :-\
Modified by Syndacate at 2:02 PM 7/28/2006
Old Jul 28, 2006 | 09:47 AM
ATrin's Avatar
Default Re: (Syndacate)
so then i need a obd1 to obd2 conversion ecu harness???
Old Jul 28, 2006 | 09:51 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">wait, wth, why are pple telling him to get an ODB1?????
If u have a 97 GSR motor, u want an ODBII P72, I do believe....but like they said, unless u have a conversion harness ((ODBII &gt; ODBI)then everything would be peachy) the plugs won't even fit into the ECU</TD></TR></TABLE>
He has an OBD1 car/harness
Old Jul 28, 2006 | 09:52 AM
ek4_b16a's Avatar
you wouldn't want to go from obd1 to obd2. that will make everything much more difficult. if you are obd1 already, stick with it. just look online for an obd1 p72 or something, don't waste the money on a obd1 to obd2 conversion harness...waste of time and money...
plus it is fine to run an obd2 motor on an obd1 ecu...nothing wrong with that...just less wiring...
but yea...do not waste money on a conversion harness from your obd1 vehicle to an obd2 ecu...trust me..it'd be better off finding yourself the correct ecu for your year...OBD1
Old Jul 28, 2006 | 05:27 PM
Syndacate's Avatar
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
He has an OBD1 car/harness </TD></TR></TABLE>
Yeah but he's got a '97 GSR...isn't that an ODBII engine...so wouldn't u need a ODBII &gt; ODBI harness....
Old Jul 28, 2006 | 05:41 PM
kiddcarbuff's Avatar
nope, use the obd1 computer
Old Jul 31, 2006 | 05:38 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Yeah but he's got a '97 GSR...isn't that an ODBII engine...so wouldn't u need a ODBII &gt; ODBI harness....</TD></TR></TABLE>
No.
Even though the engine came out of an OBD2 car it's easier to make it OBD1.
"How?"
Well first of all you can keep the 97 GS-R engine harness - it plugs right into your shock tower chassis harness plugs on the 94 Civic.
From there you can run the wires for VTEC, IAB, and knock sensor from the chassis harness plugs on the shock tower into the correct ECU pin locations and run an OBD1 94-95 GS-R P72 ECU and like magic - the engine is now OBD1!!!
This is exactly how I run my 1998 B18C5 swap - I kept the 98 engine harness and run a rechipped P28 ECU, which is OBD1, and it runs swell. I run a P28 because I don't have the dual butterfly intake manifold like the GS-R does.
Jap_Spec_Imports
Aug 10, 2009 07:14 PM
FerioVtec94
Apr 12, 2003 06:27 PM
