yay another seafoam thread!
Old Jul 27, 2006 | 11:50 AM
itsjdmbradyo!'s Avatar
Default yay another seafoam thread!
ok ive been doing alot of research on the seafoam write ups for the past few days because i plan on using i today before i change my oil.
my d16z6 has 143K on it, my question is in alot of the write ups people were saying you should or shouldnt put it in the crank case depending on the milage. so considering mine has 143K should i put 1/3 of it in my crank case or just use the BB and gas tank method?
Old Jul 27, 2006 | 12:32 PM
EG2Driver's Avatar
Default Re: yay another seafoam thread! (itsJDMbradyo!)
well the sludge in your engine may be holding the leaks back, using seafoam would remove that and you will leak. That is all in theory, no way to be sure because all engines wear differently.
Old Jul 27, 2006 | 12:48 PM
SkoundrelUSA's Avatar
cute little bastard
I have done it myself, but will probably not ever again. Nothing bad happened, just I don't want to ever use another additive to my oil again.
Old Jul 27, 2006 | 12:57 PM
Default Re: yay another seafoam thread! (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">well the sludge in your engine may be holding the leaks back, using seafoam would remove that and you will leak. That is all in theory, no way to be sure because all engines wear differently.</TD></TR></TABLE> im aware of all thise but im talking about adding it directly into to the crank case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">I have done it myself, but will probably not ever again. Nothing bad happened, just I don't want to ever use another additive to my oil again.</TD></TR></TABLE> considering you change your oil right after sea foaming i dont see it as an additative really.
Old Jul 27, 2006 | 12:58 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMbradyo! &raquo;</TD></TR><TR><TD CLASS="quote">
considering you change your oil right after sea foaming i dont see it as an additative really. </TD></TR></TABLE>
But its still in there mixing around. whatever, do what you want.
Old Jul 27, 2006 | 02:30 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 9:31 AM 11/16/2006
Global688
Nov 27, 2007 05:27 AM
B16b-EJ8
13
Apr 24, 2007 03:57 PM
NW89Hatch
Jan 20, 2006 04:19 PM
ildknyli
May 16, 2005 02:09 PM
Soon_2b_evil
Jul 18, 2003 05:36 PM
