Crank Pulley came loose, now car won't start!!! Please HELP!!
Old Jul 27, 2006 | 11:12 AM
SpEeDyPd8503's Avatar
Default Crank Pulley came loose, now car won't start!!! Please HELP!!
I have a 1995 Prelude Vtec H22a1. I was driving to work, my battery light came on. Then I noticed that my power steering was gone. When I was pulling into work my car died. I checked it out, and my crank pulley (harmonic balancer) was very loose, and my a/c, p/s, belts were gone. I had the car towed home. I bought new belts and H.B. from Honda. I put it all back together but car doesn't start.?! I think my timing could be off. Would this stop my car from starting. Could it be my valves? Should I try to fix my engine or just get a new one from Japan? If it is just the timing how would I fix that? Does anyone have the specs for timing on a 95 vtec? I need help, I miss driving my car....
Old Jul 27, 2006 | 11:31 AM
Hawkze_2.3's Avatar
Default Re: Crank Pulley came loose, now car won't start!!! Please HELP!! (SpEeDyPd8503)
I'd order a Helms manual from http://www.helminc.com
Old Jul 27, 2006 | 04:54 PM
s13_240sx_92's Avatar
didn't we see this post already?
https://honda-tech.com/zerothread?id=1658862
I think you got your answer there.
Old Jul 27, 2006 | 05:48 PM
prelude72569858's Avatar
you lost your keyway bet $100 on it!!!
Old Jul 27, 2006 | 06:09 PM
gooseman's Avatar
someone didn't tighten your pulley to spec. and it came loose and your key probably fell out. ARE THERE ANY TEETH LEFT ON THE CRANK AND THE OLD PULLEY? I THINK YOU RUINED YOUR ENGINE. JUST GET A NEW BLOCK.
Old Jul 27, 2006 | 07:46 PM
Lude Acts's Avatar
^ Get the hell out of here. If your crank pully was loose, almost 100% your timing is off. This is why your car won't start. If it is way off, the car won't start.
Old Jul 27, 2006 | 09:50 PM
paulwithap's Avatar
haha, same **** happened to me a couple months ago in my h23. i have a jdm h22 now. your crank is done. didn't you hear the tapping against the block before the belts came off?
so simple
Sep 11, 2011 07:41 AM
mayfly
May 9, 2010 09:39 PM
SpEeDyPd8503
Nov 21, 2008 09:48 AM
SpEeDyPd8503
Jun 25, 2006 09:18 PM
accordinglyevil
Jan 11, 2005 07:46 PM
