any ever instaleld ksports in an eg???
Old Jul 27, 2006 | 09:59 AM
superslow-oto's Avatar
Default anyone ever installed ksports in an eg???
im planning to install some k-sports tomarrow at home. i was wondering if anyone in here has done it before. what do i need and what are the steps... and what the heck is preloading... im clueless. i asked in the suspension forum but i had no replies......can anyone help me...thank you so much
Old Jul 27, 2006 | 10:13 AM
Sleepy_Red_hatch's Avatar
Default Re: any ever instaleld ksports in an eg??? (superslow-oto)
i havent installed Ksports, but i installed my Koni yellows + H&R race springs...they came pre-assembled so the install hould be the same as full-coilovers
-jack the car up, set on jackstands and remove wheels
**REAR**
-unbolt the shock bolt on each LCA (14MM i think? i cant remember)
-unbolt the two bolts on either side from the inside behind the access pannel that holds the shock to the body
-remove the old **** and install the new set-up, havign a friend/jack hold up the new set-up as you rebolt the shock to the bosy (loosely)
-line up the LCA into the shock fork and re-install the shock bolt
done and done.
**FRONT**
(this is a little harder, but not by that much)
-unbolt the brakelines from the old set-up
-unbolt the shock bolt from the LCA (you need a wrench on one side of this, i think)
-unbolt the shock form the body, in the engine bay, pull the bottom fork towards you and pull it over the axle being careful not to damage anything and slide the top through the upper control arm, if it doesnt fit (like mine) unbolt the upper control arm from the engine bay
-unbolt the fork from the stock shock and transfer to the new set-up
-bolt the new set-up to the body after sliding the axle through the fork , rebolt the upper control arm and bolt the fork to the LCA...zip tie the brakelines so the ywill never intefere with the spring re-install anything i forgot to mention to re-install
done and done.
-put wheels back on and BAM, lower and better at cornering then ever.
Old Jul 27, 2006 | 10:38 AM
JDMlyfestyle's Avatar
i got Ksports on my car. You do Not need to preload the suspension.
Basically do what is posted a above.
Old Jul 27, 2006 | 11:02 AM
Default Re: (JDMlyfestyle)
thanks you guys....great help...i was hesitating on weather i shoudl do it at home or bring it to the shop
ill jsut do it at home..thanks again
Old Jul 27, 2006 | 11:22 AM
Default Re: (superslow-oto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superslow-oto &raquo;</TD></TR><TR><TD CLASS="quote">thanks you guys....great help...i was hesitating on weather i shoudl do it at home or bring it to the shop
ill jsut do it at home..thanks again</TD></TR></TABLE>
do it at home, verry easy once you get to cee whats up. BUT you may need some airtools, i did it with a 2135Ti, it went really well but i needed to replace the LCAs in the back because the strut bolt didnt want to come out (but i live in salty canada and my car has 320k on it )
Old Jul 27, 2006 | 11:36 AM
Whiskeydcks45's Avatar
Default Re: anyone ever installed ksports in an eg??? (superslow-oto)
Once you get those on its time for some new rotors. But it looks good.
Old Jul 27, 2006 | 12:05 PM
h22silvia's Avatar
thats pretty low how does it ride
Old Jul 27, 2006 | 12:06 PM
Default Re: anyone ever installed ksports in an eg??? (h22silvia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22silvia &raquo;</TD></TR><TR><TD CLASS="quote">thats pretty low how does it ride</TD></TR></TABLE>
dont thread jack, IM me
Old Jul 27, 2006 | 12:21 PM
crazy sohc vtec guy's Avatar
Default Re: (Sleepy_Red_hatch)
Cali Noob
Suspension & Brakes
14
Jul 25, 2011 08:00 AM
mcgee*
Suspension & Brakes
14
Jul 24, 2011 03:48 AM
jdmsupreme2132
Suspension & Brakes
Nov 2, 2009 11:55 PM
fongyz22
Honda Civic (2001 - 2005)
Feb 3, 2008 01:59 PM
Nader_D
Aug 10, 2003 04:23 PM
