SRS light on 2000 Accord, Code 93 (Driver seat buckle)
Old Jul 27, 2006 | 09:49 AM
kchan's Avatar
Default SRS light on 2000 Accord, Code 93 (Driver seat buckle)
Any idea how much does it cost to fix this?
Could it possibly be under any recall on the SRS airbag?
Old Jul 27, 2006 | 01:27 PM
420Accord's Avatar
Default Re: SRS light on 2000 Accord, Code 93 (kchan)
Your problem may be caused by a faulty sensor in the passenger seat which does have a recall on it (for 6th gens). There's no way for me to know if this is the case in your situation. Your best bet is to take it to a dealer, explain your symptoms, and ask if the problem is under recall.
Old Jul 27, 2006 | 04:00 PM
hondadude's Avatar
WARRANTY
Old Jul 27, 2006 | 08:23 PM
someone else's Avatar
It Wasn't Me!
Default Re: SRS light on 2000 Accord, Code 93 (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">WARRANTY </TD></TR></TABLE>
Yep. Seatbelts have a lifetime warranty. Does anyone know of any company other than Honda that does this?
Old Jul 28, 2006 | 01:48 PM
V6iCkSpEeD's Avatar
Default Re: SRS light on 2000 Accord, Code 93 (420Accord)
This is a common problem on these cars, the seatbelts and their buckle do infact have a lifetime warranty!
Old Jul 31, 2006 | 06:19 PM
sirsi's Avatar
anything that has to do with srs is lifetime...its the buckle thats bad...honda has a recall on it...they will change it out for free....
Old Jul 31, 2006 | 06:25 PM
It Wasn't Me!
Default Re: SRS light on 2000 Accord, Code 93 (sirsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirsi &raquo;</TD></TR><TR><TD CLASS="quote">anything that has to do with srs is lifetime...its the buckle thats bad...honda has a recall on it...they will change it out for free....</TD></TR></TABLE>
Seat belts are lifetime. Not the srs system. If your srs control unit or an airbag goes bad you can call Honda for goodwill consideration, but it is not under "warranty".
Old Apr 21, 2016 | 10:12 PM
capt's Avatar
Default Re: SRS light on 2000 Accord, Code 93 (Driver seat buckle)
OK so first off my SRS light came on a while back. Took it in to Honda they wanted 150.00 just to read the code to see if it was something that might be covered but "the SRS unit could have gone bad and that is 800.00 to replace and not under warentee" I hate dealers. To make a long story short I figured out how to read and reset the codes. It pointed to seat belt. Back to dealer same thing different service manager. I sprayed the clasp of the belt with WD40. Reset it and it went away for 6 months. Recently the Check Engine light came on. I tried reading the code (jumping the brown and black wires on the longer connector) the code read 93... the references I found on the web go up to 92 - also it was the SRS light that blinked not the the check engine. Now after the read the SRS light and check engine is staying on AUGH!!! What do I need to do now? Thanks in advance for any suggestions. This car only has 100k on it! (2000 Accord ex)
cmasino
Apr 25, 2017 03:53 PM
richkjm
Feb 4, 2016 11:18 AM
Lou_EM1
Feb 26, 2015 06:45 PM
work9to5
Nov 10, 2007 08:39 PM
MurdersV8s
Nov 13, 2006 03:26 PM
