oil pressure reading
Old Jul 27, 2006 | 06:30 AM
ge_itr's Avatar
Default oil pressure reading
how much oil pressure reading should i get on regular idle and much should i get at 5,500 rpm?
Old Jul 27, 2006 | 06:42 AM
RTW DC2R's Avatar
Default Re: oil pressure reading (ge_itr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">how much oil pressure reading should i get on regular idle and much should i get at 5,500 rpm?</TD></TR></TABLE>
it varies. on a cold start it can be pretty high. on a warm start it can be much lower. search the archives and you will find a general idea of what most people see. mine varies on a day to day basis.
Old Jul 27, 2006 | 06:44 AM
92TypeR's Avatar
FSAE
Default Re: oil pressure reading (RTW DC2R)
Using an OEM filter (bigger style), 20-25psi at idle, and ~70 cruising above 4000.
Pressure can change +/- 10psi by just having a different sized filter.
Old Jul 27, 2006 | 06:47 AM
RTW DC2R's Avatar
and oil lines for turbos, and restrictors, and gauges, and sandwich adapters lol as far as numbers go, as long as its not Extremely LOW I wouldnt be too concerned.
Ill monitor mine next time I drive the R and post up the numbers
Old Jul 27, 2006 | 10:02 AM
mugenracer's Avatar
Mine maxes out at 85psi (6kg/cm) when the pressure release valve opens and it drops to approx 78psi (5.5kg/cm) At idle it sits steadily at approx 2.0kg/cm
Old Jul 27, 2006 | 02:23 PM
itralex's Avatar
Default Re: (mugenracer)
I'm using the oem integra filter and my pressures varies with different temperatures
at about 180F my idle pressure is around 15-20psi and 50psi @ 3000rpm
at about 220F my idle pressure is around 10-15psi and 45psi @ 3000rpm
I'm gonna switch over to a RSX filter and see how much my pressure goes up by at different oil temps and rpm on my next oil change
trulyshavedintegra
Dec 9, 2012 05:06 AM
dragvixen
Jul 10, 2009 11:20 AM
djtsmith007
Jan 3, 2007 12:08 PM
SkRiBLaH
Aug 12, 2005 10:42 AM
Audipwr1
Jul 18, 2003 02:37 PM
