stripped threads in block!
Old Jul 27, 2006 | 01:01 AM
tagperformance's Avatar
Default stripped threads in block!
Anyone know if i can put heiler coils in the block or heard of something called time serts. anybody heard of this. any help would be apreciated.
Modified by tagperformance at 2:16 AM 7/27/2006
Old Jul 27, 2006 | 01:32 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: stripped threads in block! (tagperformance)
Have a machine shop re-tap the hole.
Old Jul 27, 2006 | 03:24 PM
Default Re: stripped threads in block! (JDM_Ej)
well i talked to a reputable engine builder and re-tapping the block is not going to work either i use heiler coils inserts or timeserts
Old Jul 27, 2006 | 03:53 PM
Chiovnidca's Avatar
I've used heli-coils for stripped head bolts without any problems.
Old Jul 28, 2006 | 08:33 AM
Darton's Avatar
Default Re: stripped threads in block! (Chiovnidca)
contact Lock-n-Stitch 800-736-8261
http://www.locknstitch.com
Old Jul 28, 2006 | 09:11 AM
Acura_I-RS's Avatar
Default Re: stripped threads in block! (Darton)
a buddy of mine used time-serts, and they worked very well.. they are kinda spendy though.. it was a b16 bottom end..
Old Jul 28, 2006 | 03:39 PM
yeah i'm getting them installed monday for $250
Old Jul 28, 2006 | 07:59 PM
qfast817's Avatar
Default Re: (tagperformance)
that sucks bro, did you strip the head stud
Old Jul 29, 2006 | 04:18 AM
Default Re: (qfast817)
dude i started all of the studs by hand and snugged them , then torqued them down in sequence at 22lbs from the center to the outside. then i repeated the same step and torqued them down to 61lbs. i drove the car for a couple of days and wondered why the car kept heating up!. I figured i must of had a clogged hose or radiator so i flushed the radiator and replaced the hoses. then jacked it up high in the frt and let it run and berp for a while. then i took it around the corner and i got on it kinda hard and then the temprature shot to the red like a tach. I really new something was wrong after that. so after i got the car back up on the jack stands i took the cams and belt off went to loosening up the head bolts and the top 3 on the intake side were already loose . i could turn them by hand and i was like WTF i tried to torque them down and nothing they kept spinning. well at least when i have the inserts in i won't have to worry about the head lifting and me blowing a headgasket.
Old Jul 29, 2006 | 07:36 AM
CivicMike's Avatar
helicoils....the new threads will be much stronger than than previously!
Chance EG
Welding / Fabrication
31
Jul 22, 2015 01:53 PM
horn12007
18
Sep 2, 2010 04:21 PM
80884
Dec 8, 2004 04:09 PM
rcoolb2002
Nov 9, 2004 12:17 PM
V8 BAIT
Jul 1, 2004 01:18 PM
