sidemarker stress
Old Jul 26, 2006 | 10:48 PM
hondamoonchucks's Avatar
Default sidemarker stress
man i i just installed my sidemarkers... hell of a time...
anyways... my right parking light does not turn on when i signal...but when the headlights are on, they turn on. hmmm.. i checked the wiring and since i use 18 gauge stranded wire, i used a female connector and crimped the 2 sides of the red wire on and the 2 sides of the green wire on another connector. i checked the wiring and they all connect. why is this??
thankss
Old Jul 27, 2006 | 12:18 AM
bpr0422's Avatar
Default Re: sidemarker stress (hondamoonchucks)
Side markers should only be wired in 2 ways..
green to side marker and red to side marker
or
red to side marker and black to side marker
you should check ur connections again...
check the green wire to the corner light...
does ur side marker blink when u signal?
The green wire is the turning signal, red is the parking light signal, black is ground.
Old Jul 27, 2006 | 12:20 AM
JDMlyfestyle's Avatar
Looks like on one side you tapped into the Parking light signal. and on the other you tapped into the turn signal
Old Jul 27, 2006 | 09:14 AM
my sidemarker blinks... just my parking light doesnt
Old Jul 27, 2006 | 02:04 PM
BlueIntegraBoy's Avatar
Default Re: (hondamoonchucks)
Did you cut off the wire to the parking light/turn signal socket to where it only turns on with the headlights, and not for the turn signal?
Old Jul 27, 2006 | 10:52 PM
all i did was cut the red wire, made it connect the wire to the sidemarker and the 2 sides of the red wire... same for the green wire.
Old Jul 27, 2006 | 11:06 PM
You're not supposed to cut the red parking light completely.
Old Jul 28, 2006 | 10:30 AM
i did it exactly how i did the driver side... and the driver side works...
Old Jul 29, 2006 | 11:38 PM
bump
Old Jul 30, 2006 | 10:12 AM
help///
Old Jul 30, 2006 | 10:13 AM
Archidictus's Avatar
Unceasing Measure
Put it back to stock and do it right next time.
d16civic111
Jul 12, 2006 10:41 PM
Unjockable
Jan 27, 2004 07:25 PM
eg_type_r93
Jan 16, 2004 09:09 PM
Papa John
Dec 3, 2003 06:03 PM
