Suspension & Brakes Theory, alignment, spring rates....
How can you test INNER cv joints?
Old Jul 26, 2006 | 10:36 PM
JDM H22's Avatar
Default How can you test INNER cv joints?
My Driveshaft shop axel had a bad OUTER cv joint that clicked really bad so I ordered a new outer joint from Driveshaft Shop. After racing at the track, on my way home I noticed the car would shake under throttle. I figured that joint **** the bed. So I replaced it. It still shakes under throttle. Something else let go. I am replacing the tie rod bushings, and not that I think it is this, but also the upper ball joints. I also will check the rear motor mount since I havent check that one yet. It seems to me that it is drivetrain though. The only thing left is those inner joints. I dont want to replace them till I know they are bad, so is there any way to check or know if they are bad. thanks
Old Jul 27, 2006 | 02:54 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How can you test INNER cv joints? (JDM H22)
Shaking on accelleration is usually inner joints. Do you have a set of OEM axles to try?
It could also be your steering rack... this is what im thinking my issue is now.
Old Jul 27, 2006 | 10:45 AM
JDM H22's Avatar
Default Re: How can you test INNER cv joints? (JDM_Ej)
I did see that the boot on the rack was ripped a little. But it has been like that for a while. Its about 3 years old. Is it common for these to go that quick?
Old Jul 27, 2006 | 11:58 AM
94eg!'s Avatar
#1 Super Guy
Loved
It's very common if the passengers side boot on the steering rack is torn (manual steering only). There is a white hard plastic bushing that the steering rack slides on inside the steering gearbox. Dust will wear that sucker down & allow all sorts of play in the passengers side of the steering system...
Here is my thread that details this problem in my CRX. There is lots of good pics form other members in the later pages. Any 88-00 Civic or teg with manual steering will be the similar...
https://honda-tech.com/zerothread?id=1117870
google123
Aug 25, 2011 11:42 AM
94eh2
Feb 14, 2007 04:52 AM
JDM H22
Aug 3, 2006 10:02 PM
JDM H22
Jul 28, 2006 09:04 AM
JDM H22
Jul 28, 2006 08:16 AM
