auto to manual conversion
hey my homeboi jes got a 99 hatchback that is an auto....he wants too convert it too a manual... does anyone kno how hard it is ...too change it too a manual?..and how much? the motor is a regular...D16....soo if anyone can help!!..itll be muchly appreciated...thank you!...
D16y7 I do believe, non vtec def...
Anyawy...
it's not hard at all, u'll need a
- D-series manual transmission
- shift linkage
- shifter
- clutch pedal or clutch pedal set (just a single clutch pedal is easier)
- clutch linkage
- manual ECU for the D16Y7
That's it, ECU is just plugs, everything else ur best bet is to pull of a totalled car in a junkyard, tranny for a D series (you'll want one from a 99/00 civic hatch because the shift linkage, shifter, clutch linkage, 'n all, will all fit)
Tranny is hot swap, ANY manual D-series tranny should work, direct bolt on basically, if from those years (you might be able to use any hatchback shift linkage, not sure), the shift linkage will fit perfectly, the shifter will fit perfectly (might have to do a lil cutting in the console, but doubt it....) clutch pedal needs to be bolted/screwed in, linkage should fit fine, & that's about it
THink u g2 like cut a wire or some stupid **** like that for the park override so it'll start...but that's after the swap, and real fast
u get all the parts, no reaosn it should take u ne more than a day, very very easy
I might have forgot a piece or two but I doubt it
Like I said, best bet is to get a pickup, find a totalled out honda hb, and strip it for the aprts u need, u cna usallly get everything u need in one swipe, very easy, very quickly
Only thign I could recommend is getting all the aprts first, so there isn't much down time
Even if u've never done it before, it's very very easy
Anyawy...
- shift linkage
- shifter
- clutch linkage
I did it just recently on an EG...easy....
on an EK though you have to cut under the console, besides that you dont need after market mounts for the tranny like the eg. Easy..What i learned is MAKE SURE YOU HAVE ALL BOLTS AND TOOLS!!!!
92lxsleeper
Jul 3, 2009 12:23 PM
nightshift
Honda Civic (2006 - 2015)
15
Jun 3, 2009 04:40 PM
