98 Civic Wheel Studs
One of the wheel studs broke off when I was putting my lugs back on. It came off the rear one. Do you guys have any idea how to replace this, or any idea how much it will cost to get it fixed at a shop?
And also, is it safe to be driving around with 3 lugs on/
Thanks for input
Thanks for input
same **** happened to me...
buy it at autozone or pepboys. ask them cuz they usually keep it in the back
to install, take ur wheel off and juss bang the drum with a rubber hammer.. it shoudl pop off...or just take it to sears or a body shop... should be a rip off like 30 -40 bucks... and u can drive around with 3 lugs for a bit.. just dont do no takumi drifting ****.
take out the wheel, take the bolts off the hub or rotor, for rotor you would have to remove the caliper to take it out. take the broken stud out using hammer and a strew driver. place the new stud back into place. (stud can be purchase at autozone for about 3 bucks a piece. or go to honda and get the oem one) now put the strew driver in the back of the stud and hit it out. put the hub or rotor in to place and strew back in the bolts.
all done.
all done.
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
