need help on these ecu codes
ok the other day i went to autozone and ran the diagnostic and it came up with these 3 codes: p0420, p1259, p1457. Is there a way i can fix these problems at home or will i need to bring it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmrnguyen »</TD></TR><TR><TD CLASS="quote">ok the other day i went to autozone and ran the diagnostic and it came up with these 3 codes: p0420, p1259, p1457. Is there a way i can fix these problems at home or will i need to bring it in?</TD></TR></TABLE>
p0420=Catalyst Systeam Efficiency Below Threshold...Most likely a bad Cat.
p1259=Vtec System Malfuction...Clean the Vtec solenoid, flter might be drity.
p1457=Evaporative emissions (EVAP) Control system leakage EVAP canister systeam)...
