need help on these ecu codes
ok the other day i went to autozone and ran the diagnostic and it came up with these 3 codes: p0420, p1259, p1457. Is there a way i can fix these problems at home or will i need to bring it in?
Re: need help on these ecu codes (gmrnguyen)
can you get the one and two digits numbers? such as 20 or 3
it will make it quite a but earier to look up |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmrnguyen »</TD></TR><TR><TD CLASS="quote">ok the other day i went to autozone and ran the diagnostic and it came up with these 3 codes: p0420, p1259, p1457. Is there a way i can fix these problems at home or will i need to bring it in?</TD></TR></TABLE>
p0420=Catalyst Systeam Efficiency Below Threshold...Most likely a bad Cat. p1259=Vtec System Malfuction...Clean the Vtec solenoid, flter might be drity. p1457=Evaporative emissions (EVAP) Control system leakage EVAP canister systeam)... |
Re: need help on these ecu codes (jdm_bones)
