Wiper and blinker switch question
My wiper switch is busted in the back. I found these two items on ebay
http://cgi.ebay.com/ebaymotors...wItem
what is the intermiten wiper? is this the back wiper for the hatches?
The other item
now my light switch works... could I put my working light switch on this one?
thanks for the help
The other item
thanks for the help
Intermittent wipers are for the front wipers that wipe the windshield every ~5 secs. Since you have a DX, you should have intermittent wipers.
Check your wiper switch for INT --> LO --> HI, if it says that you'll need an Intermittent wiper switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx »</TD></TR><TR><TD CLASS="quote">okay... thanks... will the other option work?</TD></TR></TABLE>
You can use the non-INT switch on your car, but LO will be INT I think.
low/high will work normally. Int will simply never be selected.
if you need a switch with the int setting, hit me up, I have one sitting here.
If you're looking to add intermitent wipers you need the switch and the module that plugs into the rear of the fuse box. (i have that too)
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
SR20 Inside
Jan 25, 2006 09:24 PM
