EJ1 Power Windows are slow
Old Jul 26, 2006 | 11:56 AM
Metalluthier's Avatar
Default EJ1 Power Windows are slow
Was going to ask, what's the exact problem when your window motors are becoming too sluggish? Is it just the motor going out? Or some other nice electrical problem, because I just put a new battery in my car. The worst on my car is the passenger window, it's so slow
Dark Angel - We Have Arrived (1984) - 03 - Falling From The Sky.mp3 [192Kbps] (04:23)
Old Jul 26, 2006 | 12:24 PM
sohcvtec1995's Avatar
you need to greese the tracks. i beleive they recomend every oil change to do this.
Old Jul 26, 2006 | 01:15 PM
egsleepercivic's Avatar
I used silicone spray on mine, they were as good as new
Old Jul 26, 2006 | 04:57 PM
Default Re: (egsleepercivic)
Hmm. Ok then, thanks guys!
Dyscrasia - Septical Stomach-Pumped Remnants (2003) - 3 - Semen Soaked C-Section.mp3 [192Kbps] (02:50)
Old Jul 26, 2006 | 05:01 PM
brockscivic's Avatar
Default Re: (Metalluthier)
yeah you can get that silicon spray at walmart for less than 2 bucks a can...good stuff
Old Jul 27, 2006 | 05:06 PM
ssd's Avatar
ssd
what exactly are you suppose to spray ?
Old Jul 27, 2006 | 05:59 PM
I sprayed it on the tracks(inside the door) not the regulator, if you have tint let it dry before you roll them down.
Old Jul 27, 2006 | 06:44 PM
ph0shizzle's Avatar
sprayd it on the tracks? what you mean?like take out the door panels and spray the metal scissor lookin thing? sorry i dunno the names and dunno that much its cuhz i jus did a power window conversion on my ek and it goes up really slow
Old Jul 27, 2006 | 06:47 PM
there are tracks inside the door(at the edges of the window) they guide the window inside the door, for the regulator(metal scissor) i would hit that with WD 40 or something similar.
gl
Old Jul 27, 2006 | 06:51 PM
ph0shizzle's Avatar
is this something that almost anyone could do even though they dont know that much about power windows? like do i have to block anythin off? or if i accidently spray on somethin else somethin wil go wrong
Old Jul 27, 2006 | 06:54 PM
yeah, if you can remove the door panel(inside the car) without breaking too many clip, also you have to be able to use a aerosol can
you can probably find a how to on removing the door panel if you search this site
gl
Old Jul 27, 2006 | 07:00 PM
ph0shizzle's Avatar
well yea i know how to remove door panels thats easy, but then after i do that, i spray the inside door where the windows go up and down with silicone spray and spray the regulator with wd40?
Old Jul 27, 2006 | 07:05 PM
yup tracks silicone, reg wd
Old Jul 27, 2006 | 07:09 PM
ph0shizzle's Avatar
alright thanks
Old Jul 27, 2006 | 07:47 PM
Purple94EX's Avatar
Im having the same problem and someone posted in my thread to try a new switch and odd enough when i used the passenger switch to roll my passenger window up, it seems faster, rolled up 1 second faster actually. Maybe i better try this grease for the metal. Any pictures of what this substance looks like...bottle wise. Thanks
Old Jul 28, 2006 | 07:23 PM
ph0shizzle's Avatar
Default Re: (ph0shizzle)
i waited in line at wal mart for like 15 mins then found out u have to be 18 to buy silicone spray???
Old Jul 28, 2006 | 07:27 PM
Syndacate's Avatar
word
I have the same exact problem with my EJ1
groggy and sluggish, like the battery's dead
WD-40 in the tracks eh, I'll definately have to try that..
ur talkin about the tracks at the bottom, right?
Old Jul 28, 2006 | 07:44 PM
knockout's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
ur talkin about the tracks at the bottom, right? </TD></TR></TABLE>
spray all the "joints" and rollers in the tracks.
Old Jul 28, 2006 | 08:11 PM
Ej1_coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">word
no no no .. lithium greese in the tacks. That is what the window slides up and down. Take your door panel off, look in the door skeleton and roll window down, what the window slides down.. greese that.
Use the WD40 on the regulator (scissor looking thing).
Old Jul 28, 2006 | 09:06 PM
Syndacate's Avatar
Default Re: (Ej1_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Use the WD40 on the regulator (scissor looking thing).</TD></TR></TABLE>
lol thx for explaining the parts of a power window :-P
Aight, WD-40 in the actuator parts that move, and lithium greese in the track, thx O.o
Hopefully it'll run smoothly
I had the same prob w/ my sunroof, it wasn't greesed enough, didn't pop up all the way b4 it moved back and put 2 scratches about 1.5 inches long in the roof on both sides of the sunroof, pissed me the expletive off, but greesed it up and worked fine since :-\
Thx
quique29
Mar 29, 2014 11:00 PM
Adog12
Nov 23, 2011 07:28 PM
sooskay
Sep 9, 2006 06:59 PM
CaptivaBlue
May 10, 2005 07:12 PM
holeeray
Mar 6, 2005 01:36 PM
