3 quick questions!
Old Jul 26, 2006 | 09:03 AM
darkside788's Avatar
Default 3 quick questions!
Hey sorry to bother you guys with a question that has been asked probably a thousand times if not more...i tried searching but i get errors..sorry!
anyway,i want to put a 16" wheel on my civic eg...
1)what tyre size do you guys recomend??
2)what offset will make the wheel come flush to the fender??
3)how much can i lower it afterwards???making sure it doesnt touch...
thanks for your patience!!
Old Jul 26, 2006 | 09:08 AM
Dilly's Avatar
Default Re: 3 quick questions! (darkside788)
1) not sure with 16's. maybe either 195 or 205?
2) i believe 40 offset will come flush with the fenders. 35 sorta stick out just a bit.
3) ummm.. i'd say about 1.5 or 2 if you want. most people here on HT would say slam it to the ground. but since you dont want to rub, then 1.5 would be good. but thats just me.
Old Jul 26, 2006 | 09:23 AM
LowSlow93Sol's Avatar
1) with 16" rims the closest tire size is 205/40 (its about 1/4 inch smaller than stock) Then next up is 195/50. About 1 inch bigger than stock. a 45 profile tire would work too in this size but expect to pay out the *** for it.
2)I would go with a 40 offset.
3)you can slam it to the bumpstops with the tire size i listed. Nothing with rub. It is designed that way.
Old Jul 26, 2006 | 09:26 AM
Default Re: 3 quick questions! (onefast93sol)
ok thanks very much for the help so far!!
ok so the 205 40 sounds good,i can even drop it and it wont rub...
um,how does a 16 look with a 40 sidewall?is it a bit big?got any pics??i sorta like the real low profile look...
Old Jul 26, 2006 | 09:27 AM
sol2hatch's Avatar
Default Re: 3 quick questions! (dillywong)
i imagine you could go a little wider with 16, depending on what wheel. I have 15" si wheels, and i have 205s on them. and 1.5-2" is good
Old Jul 26, 2006 | 09:38 AM
Default Re: 3 quick questions! (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote">i imagine you could go a little wider with 16, depending on what wheel. I have 15" si wheels, and i have 205s on them. and 1.5-2" is good</TD></TR></TABLE>
True 215/40 is actually the perfect size. But it is not very cheap. Search http://tirerack.com for the specs and info that you need.
yaryar
Jan 10, 2008 07:11 AM
sain167
Jul 21, 2004 08:06 AM
ianp
Jun 26, 2002 04:13 AM
mattL
Jan 17, 2002 08:44 AM
nEoMuGen
Jan 16, 2002 07:07 PM
