LS Swap in 00 EK Hatch
Old Jul 26, 2006 | 08:39 AM
DXCIVICHB's Avatar
Default LS Swap in 00 EK Hatch
I am going to put a 96 B18B LS Swap into my 00 DX Hatch it currently has the D16Y7 with the nasty Manifold/Cat Combo OBD2. Is there any other part's i should look into getting prior to the swap. Ie: will the stock exhaust match up What about the ls radiator hoses? etc. Vacum Lines? Tune up Parts?
I appreciate any an all help.
Thanks,
Matt
Modified by DXCIVICHB at 11:06 AM 7/26/2006
Old Jul 26, 2006 | 09:28 AM
SE3Pimp's Avatar
Default Re: LS Swap in 00 EK Hatch (DXCIVICHB)
the stock exhaust from catback will match up. its good to change the oil and filter, coolant, spark plugs, cap, rotor, air filter, plug wires, gas filter after the swap to get it running top notch. make sure you use the correct ecu as well.
Old Jul 26, 2006 | 09:46 AM
DXCIVICHB's Avatar
Cool i was worried about that stupid cat/manifold setup on the d16y6 setup. Yea its a complete swap appreciate the advise
SmOkIneLf
Nov 26, 2008 08:32 AM
CTRwannaB
Apr 12, 2006 09:52 PM
2 point 0
Jul 22, 2004 02:04 PM
