Changing Fuel Pump
Old Jul 26, 2006 | 08:38 AM
nsr_prelude's Avatar
Default Changing Fuel Pump
Hi I was just wondering if anyone could tell me how to change my fuel pump in my 92 Prelude.
Old Jul 26, 2006 | 09:12 AM
MrLude1's Avatar
Default Re: Changing Fuel Pump (nsr_prelude)
Remove your back seat & rear center console as well as your rear liner from the trunk. Then, you'll see the metal plate w/a harness line feeding it. Unscrew the 5 philips screws to access the tank. Diconnect that harness from the pump feed top.
Unbolt the 6-10mm nuts (drivers side) & the fuel line. Be carefull not to lose any of the washers from the fuel line. From there you should be able to just lift out(w/some angled manuevering) the pump. When you reassemble everything, make sure the rubber gasket aroung the pump's opening is secure or you'll smell & spill an extra $4 of gas w/each launch/turn. Good luck!
Old Jul 26, 2006 | 09:39 AM
92blkJDMh22's Avatar
ummm... i dont know about you, but i didnt have to remove my rear seats...... i installed a walbro 255 by just taking out the trunk lining.... you have 100 access to that place through the trunk in 4th gens.... not sure about 5ths....
Old Jul 26, 2006 | 11:09 AM
petern101's Avatar
Default Re: Changing Fuel Pump (92blkJDMh22)
it makes it much easier to remove the back seat.
mitchell_2kSiR
Jun 9, 2008 12:36 PM
KevronsEG
Jul 6, 2007 02:47 PM
1990 CRX Si
Jan 9, 2006 05:08 AM
SpeedMonkeyRacing
Nov 29, 2002 06:08 AM
clean
Sep 26, 2001 11:15 AM
