Car is still clonking bad...
Old Apr 22, 2002 | 06:28 PM
cbrf-3's Avatar
Default Car is still clonking bad...
Installed some poly inserts in the motor mounts today and it still makes a loud clonking noise when going down gravel or rough road. I've replaced the following
all the bushings
steering rack twice
ball joints
cv joints
shocks/springs
Z-10 crossmember
bridgestone potenza so-3's
Its done this noise ever since ive gotten the car and its just gotten worse over time. It also effects that tight go-cart feel that the crx has. The car dont feel as tight to the road. So do i just give up after 2 years of troubleshooting and sell it and get a mr2 turbo or do you guys got some ideas.
Old Apr 22, 2002 | 07:51 PM
cbrf-3's Avatar
Default anyone?
any ideas?
Old Apr 22, 2002 | 07:56 PM
89 CRX SI's Avatar
Default Re: anyone? (cbrf-3)
Is it any steering related or while moving or while going over bumps.
Jack up your car. Put your hands on one wheel at 12pm and 6 pm position (imagining your wheels is a clock) then jerk it back and forth. Any movment here (more then normal) usually suspects suspension problems.
Then do the same at 3 and 9 position and that usually signifies steering problems.
Did you replace your steering rack bushings?? thats what mine was???
Let us know so you dont have to buy a MR2
Old Apr 22, 2002 | 08:30 PM
cbrf-3's Avatar
Default Re: anyone? (89 CRX SI)
I've done that test thousands of times and so have the 20 or so mechanics that have looked at it. I've had two brand new steering racks put on and the rack end bushing ist fine. The car needs a pentagram on the hood its evil. Whats wrong with the mr2 i think that would be a nice step up even though its more difficult to work on. Thanks for the ideas though on what it could be.
Old Apr 22, 2002 | 08:56 PM
89 CRX SI's Avatar
comon ma its a CRX ........ mr2 's are nice sutocross cars. but CRX's corner faster if you get that figured out.
Replace you supension with polly urethane parts... all of it? done it yet?
Old Apr 22, 2002 | 09:01 PM
cbrf-3's Avatar
Yup i've got the full energy suspension master kit installed
Old Apr 22, 2002 | 09:03 PM
flat-blk-HB's Avatar
**** my car makes noise too..i have got figured it was some thing with lowering my car b-cause that is when it started.i also put 92-95 struts on my car too.so maybe they are just too diff?????
Old Apr 22, 2002 | 11:10 PM
chhuong's Avatar
Default Re: anyone? (89EF-BCUMBIE)
How about wheel bearings, bent knuckles, bent lca's, bad ball joints???? I'm just throwing stuff at ya to look at!! HTH
Old Apr 23, 2002 | 12:39 AM
REX VT's Avatar
Default Re: Car is still clonking bad... (cbrf-3)
I would suggest it is the upper control arm+ball joint but since you've already replaced it..
Steering rack: you've also replaced the steering pilar ?
hybrid90
Suspension & Brakes
Jul 30, 2019 11:47 PM
dc2JDMwhore
Suspension & Brakes
Oct 18, 2011 05:33 AM
ScottF
Nov 19, 2010 12:36 PM
PinoyDelS0l
Suspension & Brakes
Dec 10, 2009 07:59 PM
civicboisi
May 5, 2003 03:17 AM
