my check engine light is on in my 92 prelude
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kartoon529 »</TD></TR><TR><TD CLASS="quote">what are the possibilities for it being on? and so is my break light on the dash. all my lights work though. </TD></TR></TABLE>
you have to tell us what code you are throwing...without knowing that, none of us can help you. As for the brake light being on...you have a bulb out...find out which one it is. I had it on for a while...1 on my 3 brake light bulbs was busted...
http://www.92lude.com/diagnose_error_codes.htm
for the CEL light
and as far as the brake light, check your brake fluid.
for the CEL light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">Or, go to AutoZone and tell them your check engine light is on</TD></TR></TABLE>
I went to autozone once, and they said they could only check OBD2, and not OBD1...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atljustin06 »</TD></TR><TR><TD CLASS="quote">
and as far as the brake light, check your brake fluid.</TD></TR></TABLE>
i dont think this is causing his light to come on
it depends on whether or not it's his red brake light or his ABS light. i know in my 89, my brake light (the same one that illuminates when the e-brake is pulled) turns on when i have low brake fluid. topping it off makes it go away.
however 4th gens might be a tad different, but checking it anyway to make sure won't hurt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atljustin06 »</TD></TR><TR><TD CLASS="quote">it depends on whether or not it's his red brake light or his ABS light. i know in my 89, my brake light (the same one that illuminates when the e-brake is pulled) turns on when i have low brake fluid. topping it off makes it go away.
however 4th gens might be a tad different, but checking it anyway to make sure won't hurt</TD></TR></TABLE>
its an S model, so no abs for HER, yeah...she said she was a chick in another thread..
so i think she is speaking of the red brake light, which for me, meant a broken bulb/burnt bulb.
and you're right, checking it wont hurt a thing.
