Running 4gaug wire threw my 97 Civic LX
Old Jul 25, 2006 | 07:54 PM
M^Dawg's Avatar
Default Running 4gaug wire threw my 97 Civic LX
Im going to be installing my system tommorow, the question is where is a easy way to run this fat 4gaug wire threw my firewall at? Be nice to know a good place so I dont have to spend much time doing this.
Old Jul 25, 2006 | 08:05 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Running 4gaug wire threw my 97 Civic LX (M^Dawg)
next to the battery there is a grounment. easy as cake.
Old Jul 26, 2006 | 04:21 AM
B18C_EJ8's Avatar
It's actually under the battery tray... Remove the battery, then unbolt the battery tray and you'll see it right there... Can't miss it.
Old Jul 26, 2006 | 07:23 AM
hkboy87's Avatar
im a noob at mechanical work too..i have the same car and wondering if running 4awg wire to the trunk requires a lot of diassembling...is this do-able for someone with little knowledge?
Old Jul 26, 2006 | 04:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: (hkboy87)
Yes it is doable, it does require some dis-assembly of the cars interior, remove pass. seat, [4 bolts, not that hard] remove rear seat, [one bolt for the bottom, back splits may not have to be removed, maybe 3 bolts at the most for pass. side split, remove pass kick panel trim, "pop" off the sill plate, [rocker panel trim cover] carpet is normally attached to trim fold carpet out of the way, run 4ga cable keeping in mind what has to go back where, you do not want to pinch the power cable, keep ir out from under the rear seat. 94
Old Jul 26, 2006 | 04:23 PM
02 accord's Avatar
Default Re: (fcm)
I don't see a reson to remove the seats. I did a few installs where only the kick panel trim and door sill plates were removed, and the wire was run under them. I never had to pull out seats.
Old Jul 26, 2006 | 08:19 PM
rlockwood's Avatar
Default Re: (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">I don't see a reson to remove the seats. I did a few installs where only the kick panel trim and door sill plates were removed, and the wire was run under them. I never had to pull out seats.</TD></TR></TABLE>
I seem to recall it being necessary in my brothers ek, but that was quite awhile ago..
its certainly not necessary in an eg, but it does make things easier (even better is completely gutted)
Old Jul 27, 2006 | 06:54 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">I don't see a reason to remove the seats. I did a few installs where only the kick panel trim and door sill plates were removed, and the wire was run under them. I never had to pull out seats.</TD></TR></TABLE> Didn't say you had to do it, it just makes running the cable a lot easier, as for the seats, yes you can get away with not removing the drivers seat, but the rear seat, [bottom] is a must, if you did not on your "few installs" then you must have ghetto run the wire in the rear, [stuff it down between the seat and the rear side trim panel] 94
Old Jul 27, 2006 | 07:06 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">you must have ghetto run the wire in the rear, [stuff it down between the seat and the rear side trim panel]</TD></TR></TABLE>
Done my fair share of those!!
Works just as well in most cases though, because it'll eventually settle down sortof kinda "under" the seat...
Old Jul 27, 2006 | 10:18 AM
hkboy87's Avatar
i did the install yesterday for the power wire..i have a 4dr so i dont have to remove the seat...but the problem is punching through the firewall under the batery...i cant remove the bolts that holds the batery tray and that rubber gromet is so freakin tight its hard to put any thing through it.
Old Jul 27, 2006 | 11:10 AM
B18C_EJ8's Avatar
Then drill a hole in the clutch plate if you've got an auto, or right in that general area if you've got a 5 speed... Plenty of room over there...
Old Jul 27, 2006 | 11:44 AM
02 accord's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Done my fair share of those!!
Works just as well in most cases though, because it'll eventually settle down sortof kinda "under" the seat... </TD></TR></TABLE>
Yep. That's what all mine did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Then drill a hole in the clutch plate if you've got an auto, or right in that general area if you've got a 5 speed... Plenty of room over there... </TD></TR></TABLE>
Or find another grommet through which you can fit the wire. I have my wire running from the battery (passenger side) through a grommet on the driver's side, because that grommet was out in the open and easy to get to.
Old Jul 27, 2006 | 12:11 PM
fcm's Avatar
fcm
Old Fart
Works just as well in most cases though, because it'll eventually settle down sortof kinda "under" the seat... </TD></TR></TABLE>Noooooo not you, your being sarcastic, right? 94
Old Jul 27, 2006 | 12:15 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Noooooo not you, your being sarcastic, right? 94 </TD></TR></TABLE>
Nope... Serious... Especially when I was working alone and the other asses would schedule 2 appointments for the same time slot, and especially on the seats that you needed to unbolt...
Prophet1990
Feb 18, 2012 11:21 AM
OrangeTeggy
Oct 26, 2009 03:35 PM
EG6 PSI
Dec 31, 2008 01:27 PM
Mashi2Choco
Apr 21, 2008 11:29 AM
b20integrapower
Dec 30, 2005 06:21 PM
