B16 trans + KAAZ dif ?s
Old Jul 25, 2006 | 06:50 PM
DC4_MADMAN's Avatar
Default B16 trans + KAAZ dif ?s
B16 trans- fluid capacity?(not sure if all Bseries trans hold same capacity)
KAAZ dif- use KAAZ gear oil or will Torco Gear oil be just as good?
I used to run a clutch type dif(EATON) in my mustang and used Torco with no problems.
Just trying to figure out what gear oil and how much I need to purchase. Thanks.
Old Jul 26, 2006 | 12:45 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: B16 trans + KAAZ dif ?s (DC4_MADMAN)
I believe B-series manual transmissions hold 2.5 quarts.
Old Jul 26, 2006 | 12:20 PM
ED9man's Avatar
I called Kaaz and asked then, they said run any non-synthetic GL-5 MT-1 gear oil. They also said that if you want it to be a little smoother, you can run Ford friction modifier, I found I didn't need to. I used to run Honda MTF and the unit didn't like it, I could've damaged it. Holds 2 quarts.
Old Jul 26, 2006 | 12:23 PM
DC4_MADMAN's Avatar
Default Re: (ED9man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man &raquo;</TD></TR><TR><TD CLASS="quote">I called Kaaz and asked then, they said run any non-synthetic GL-5 MT-1 gear oil. They also said that if you want it to be a little smoother, you can run Ford friction modifier, I found I didn't need to. I used to run Honda MTF and the unit didn't like it, I could've damaged it. Holds 2 quarts.</TD></TR></TABLE>
blowoutj00si
Oct 3, 2008 08:40 PM
darkblackH2B
14
Jul 30, 2008 07:37 AM
2ndchirp
Apr 5, 2008 03:24 PM
xxnuttybarxx
Aug 21, 2007 06:05 PM
junkyard racer
14
May 8, 2006 02:50 PM
