Power Steering Fluid?
Hey guys, I'm sorry to bother you with such a simple question but I was doing some check ups on my dad's 00 accord ex and the power steering was kinda low. So I looked it up in the manual and it recommends (almost makes it a requirement) that I use genuine honda power steering fluid. Is this really the case or can I use some aftermarket brand? Sorry if this is a repost but I did a serach on this forum and found nothing
Thanks for your time guys, really appreciate it.
i guess or online Honda OEM parts suppliers...
side note: I've used that bardahl stuff & no problems... i've used a dolla store turkey baster to suck out old/black cruddy fluid & replaced w/ this stuff 2 years ago. NO PROBLEM ever since the transfusion of fresh fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">...OEM-compliant power steering fluid that meets Honda’s requirements.
Regular power steering fluids are not suitable for Honda power steering units which require a fluid with viscometric properties. The fluid meets all Honda specifications to keep power steering units operating smoothly and quietly at all speeds.
It also contains a sealer and conditioner to reduce pump wear and prevent leaks due to hardening and shrinkage of seals.</TD></TR></TABLE>
i got a question on this one. how do u replace the old power steering fluid with the new fluid? is it like changing the oil where u flush it or is it like refilling a wind shield wiping fluid?
I bought a one dolla turkey baster.... suck old crap out, install fluid, drive a bit, repeat process until fluid is clear...
another way:
click me
another way:
click me
TallGuyTurbo
Oct 6, 2007 04:29 PM
