turnsignal problem is molesting my brain!!!
Ok, I was driving along and hit my turnsigal, nothing. No noises, no click, no fast blinking, nothing. There is no clicking coming from the flasher, the little arrows on the instrument cluster dont light up. I relaced the flasher, the fuse, and even the whole turnsignal switch on the steering column. What could this be? Does anybody have any wiring diagram for the turnsignals. Like ground locations, fuses, relays, flashers? 1991 Honda Civic Si hatch
Thanks!!
Thanks!!
umm it sounds to me like it is time to change ur blinker fluid.
check this site out they have the blinker fluid u need
http://kalecoauto.com/index.php?main_page=index
has to be ur hazard switch, i had the same problem, set an appt to see why they werent blinking and my friend comes over, plugged my hazard in and i was like wtf cause it was workin lol
yea when i was ripping out my dash..and i drove my car w/o a dash..the hazard switch HAD to be in the circuit for the turn signals to work.....just make sure the hazard switch connection is secure...take off the cluster and make sure its properly inserted and all.......hope this helps...cuz it sorta helped me... when you said nothing worked..no clicking..no gauge cluster turn signal lights...sounded like you didn't have the hazard switch connected properly
See my car is a 91.. So my hazard button is to the right of the ignition. Kinda like where the sunroof button is, but on the other side of the steering wheel. So why would I have to take cluster off.
