Max Current Pull of Stock ECU Injector Drivers?
Old Jul 25, 2006 | 02:50 PM
Suprdave's Avatar
Default Max Current Pull of Stock ECU Injector Drivers?
Long story short...I need to know what the max current pull is of the Injector Drivers before you burn them out? Anyone know exactly?
Old Jul 25, 2006 | 03:19 PM
blundar's Avatar
I have the datasheet somewhere...
Made by SGS Thompson I believe
STA413A
That will tell you what the manufacturer says will kill them, but not EXACTLY what you want to know.
Old Jul 25, 2006 | 05:09 PM
Jim Truett's Avatar
Default Re: (blundar)
The datasheet states 3 amps as the absoulte maximum, and I assume that is per transistor (there are four independent transistors in each STA413A). So I would try and pull no more than 2.5 amps off of each injector circuit, especially since there is no heatsink for the drivers.
chintanwall
Honda Civic (2001 - 2005)
Sep 17, 2016 01:06 AM
B_Swapped93
Apr 24, 2013 08:44 PM
TURBO DC2
Jun 3, 2005 11:10 AM
