I want to nab the CRX Sir brakes, what caliper does it use?
Old Jul 25, 2006 | 01:29 PM
ProjectDarkBlack's Avatar
Default I want to nab the CRX Sir brakes, what caliper does it use?
Well the brakes are the same size as the integra ones I believe, and they are designed for a civic. However I don't know what type of caliper they use, anyone know? CRX Forum? ha ha. It would suck to have to find pads for parts not made in america.
Old Jul 25, 2006 | 01:48 PM
crxgator's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (ProjectDarkBlack)
what is the part number on one of the calipers?
Old Jul 25, 2006 | 01:49 PM
EL Vap133's Avatar
They appear to be the same as 90-93 Teg brakes.
Old Jul 25, 2006 | 02:01 PM
coot_er's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">They appear to be the same as 90-93 Teg brakes. </TD></TR></TABLE>
can anyone confirm?
also does anyone know how big the master cylinder is?
anyone know how big stock wheels and tires are?
Old Jul 25, 2006 | 02:04 PM
crxgator's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (coot_er)
tires are 195/60/14 for crx sir...
wheels 14 x 5.5 i believe or just 14 x 5...
Old Jul 25, 2006 | 02:34 PM
Crx Jimmy's Avatar
dont get them , the knuckle is different and you will need different tie rod ends that arent available here.
Old Jul 25, 2006 | 03:00 PM
trrbl1bmx's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">dont get them , the knuckle is different and you will need different tie rod ends that arent available here. </TD></TR></TABLE>
He is not telling you a lie! I had to find out the hard way but I was lucky enough to sell em off to someone else before I got discouraged.
Old Jul 25, 2006 | 04:03 PM
coot_er's Avatar
i still want to know how large the rotor and master cylinder are
Old Jul 25, 2006 | 05:20 PM
what the F, password JDM sells them. Decent price too
Old Jul 25, 2006 | 05:42 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">
i still want to know how large the rotor and master cylinder are</TD></TR></TABLE>
10.2 rotor and prolly 15/16 master cylinder...
Old Jul 25, 2006 | 05:57 PM
EL Vap133's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
10.2 rotor and prolly 15/16 master cylinder...</TD></TR></TABLE>
Old Jul 25, 2006 | 07:49 PM
JesseCRX's Avatar
I can confirm that they do indeed use 90-93 integra calipers. And if you use the SiR knuckles you will have to get ahold of SiR tierods. USDM CRX tierods don't work without modifying them.
Old Jul 25, 2006 | 09:23 PM
Tyson's Avatar
so i guess youd be better off getting 90-91 EX knuckles. those have integra brakes too with wider spacing for larger rotor, but knuckle is otherwise identical to Si.
Old Jul 26, 2006 | 12:54 PM
JesseCRX's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">so i guess youd be better off getting 90-91 EX knuckles. those have integra brakes too with wider spacing for larger rotor, but knuckle is otherwise identical to Si.</TD></TR></TABLE>
Are you sure it's 90-91 kuckles and not 92-95? Someone confirm this please.
Also, will someone post the link to buy the JDM CRX SiR tie rods. I need them badly.
Old Jul 26, 2006 | 12:57 PM
Tyson's Avatar
Default Re: I want to nab the CRX Sir brakes, what caliper does it use? (JesseCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesseCRX &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure it's 90-91 kuckles and not 92-95? Someone confirm this please.</TD></TR></TABLE>
100% sure. 90-91 EX, no EX model prior to 1990.
i've sold a few sets. here are pics of you arent convinced.
you dont want to use EG knuckles on an EF.
if anyone has a source for UK/JDM parts, id like to know too quite frankly.
Old Jul 26, 2006 | 01:02 PM
JesseCRX's Avatar
if anyone has a source for UK/JDM parts, id like to know too quite frankly.</TD></TR></TABLE>
So the 90-91 EX has a setup similar to a 90-93 integra? Interesting. I never knew that. I'll have to do some junkyard hunting asap.
Old Jul 26, 2006 | 01:26 PM
EL Vap133's Avatar
So the 90-91 EX has a setup similar to a 90-93 integra? Interesting. I never knew that. I'll have to do some junkyard hunting asap. </TD></TR></TABLE>
Yes, similar but not identical.
Old Jul 26, 2006 | 01:27 PM
Tyson's Avatar
rotor and caliper are the same.
the rears however are drum brakes on the EX.
and fwiw has a 3540 brake prop valve, not a 4040. and the largest EF MC size 15/16", and brake booster 9" vs normal EF 8".
Old Aug 8, 2006 | 11:46 AM
jdmboyef9's Avatar
OK, I have SiR knuckles on my car and they do work!!!!!!!!!
The tie rods need to be adjusted out to work but they do fit. The SiR brakes and Calipers are the same as a 90-91 EX only(not si,lx,dx), The EX fits easier but the knuckles on the SiR are more beefly. It also works best with an Integra non-abs proportion valve. Do not use integra knuckles or try to put teg rotors and cal on a non ex/SiR hub, they won't fit. The teg knuckles sit further back in the wheel well and it looks funny.
teler86
Suspension & Brakes
Jun 12, 2005 10:09 PM
Ef Si
Mar 16, 2005 08:09 AM
CrxEDguY
Dec 22, 2004 05:36 PM
EFin' Kyle
14
Nov 12, 2004 01:36 PM
CircuitFG
Oct 20, 2003 03:54 PM
